Results 1 to 10 of 12
Thread: Create a custom Sheet Pile LineType
    Member Jay Zallan's Avatar
    2015-11
    Los Angeles
    42
    Default Create a custom Sheet Pile LineType
    Can someone help me in creating a linetype that would look like the attached drawing??? I've had no luck with adding the geometry (even after creating it as a shape) to a linetype.
    -VjdX
    I could stop if I wanted to lmitsou's Avatar
    2003-01
    UK
    219
    Default Re: Create a custom Sheet Pile LineType
    Quote Originally Posted by vjdx
    -VjdX
    Try this and let me know if it works for you.
    Earth
    9,805
    Quote Originally Posted by lmitsou
    Missing the shape file.
    R.K. McSwain | CAD Panacea |
    2003-01
    UK
    219
    Quote Originally Posted by rkmcswain
    There is only one thing for me to say R.K. : !!!!!!! D'OH !!!!!!!!
    (please find revised file attached)
    2015-11
    Los Angeles
    42
    acad 2006 says bad line #14...i'll include the error message in a capture. i must run and i'll check back and try the line again tonight. Thanks!!!:
    Earth
    9,805
    Works here. Make sure that you put the shape file in a directory that is in your support file search path.
    2003-01
    UK
    219
    Just tried to a computer that runs AutoCAD LT 2006 and works fine there. As RK said...
    ...Make sure that you put the shape file in a directory that is in your support file search path.
    Thanks for the feedback RK
    2015-11
    Los Angeles
    42
    Talk about D'OH...the support path would help, i guess!!!
    Thanks so much!!!
    2003-01
    UK
    219
    Thanks so much!!!
    Your support file search path is under Tools-->Options then you open the first Tab which is called Files and then you expand the first category which is called Support Files Search Path. Make sure the directory you saved your shape file is included there.
    Earth
    9,805
    Thanks so much!!!
    I don't think he was asking for help regarding the support file search path, I think he was just saying that he came to the realization that this was needed.
  1. 2014: Create a custom linetype with two colors
    By boyerd492098 in forum AutoCAD General
    Last Post: 2015-05-23, 10:22 PM
  2. Sheet Pile linetype
    By awiebe in forum AutoCAD Customization
    Last Post: 2011-05-02, 06:51 AM
  3. Create a custom linetype with an Arc in it
    By tyeelaw13 in forum AutoCAD Customization
    Last Post: 2006-07-14, 03:49 PM
  4. Create a custom Fence linetype
    By Damian_E in forum AutoCAD Customization
    Last Post: 2006-07-12, 08:18 AM
  5. Create a custom bold dot linetype
    By nanoaguilar2000 in forum AutoCAD Customization
    Last Post: 2004-09-28, 06:19 PM
