Thread: Earthwork Quantities...Your Thoughts?
    100 Club Phil Ferguson's Avatar
    2002-08
    Buckeye State
    137
    Lightbulb Earthwork Quantities...Your Thoughts?
    For those of you that do subdivision work...How do you go about calculating earthwork volumes?
    I'm not talking about the actual steps taken within Land Desktop to perform the calculation...more so the method used to arrive at your final quantities.
    I have seen people simply calculate the overall volume and that's it (maybe with some manual calculation using area in roadway to subtract/add cut or fill at sub-grade or use a total area disturbed to calculate topsoil to be stripped) and then compare to a contractors quantity to see if they're in the "ballpark" and then use the contractors quantities for an engineers cost estimate.
    Around here, we tend to be a little more particular. We have gone so far as to lower existing surfaces a certain amount to simulate a surface stripped of topsoil...or lower a proposed surface a certain amount to sub-grade and use parcels to calculate earthwork volumes within streets. We may choose to use a number of parcels in roadways and on lots to calculate volumes in different scenarios...i.e. Ex. Surface (adjusted for topsoil) -vs- Prop. Surface (adjusted to sub-grade) with 10% compacted fill in roadways, Ex. Surface (adjusted for topsoil) -vs- Prop. Surface with 10% compacted fill in areas from the roadway to the rear of building pads, Ex. Surface (no adjustment) -vs- Prop. Surface with no compaction in rear yards. It is not uncommon for us to take trench dirt into account as well. As you can probably imagine, this method can get a little "intense" sometimes (not to mention what happens if our quantity differs from the contractors).
    Where we have run into trouble recently is when we model a surface to sub-grade (in roadways) for purposes of preliminary design...and then when the project is all but submitted for approval, we go back and perform final earthwork volume calculations and try to compare "apples to apples" and need to start all over again with the final proposed surface.
    I am just curious to know what types of methods/processes others have used to calculate earthwork volumes for an entire site or a building phase within a site.
    Also...if any of you have similar experiences with Civil 3D, what is the workflow like when trying to accomplish these tasks?
    I could stop if I wanted to mom of 3's Avatar
    2004-07
    jUSt in the middle
    366
    Default Re: Earthwork Quantities...Your Thoughts?
    Wouldn't you create a new surface with your proposed information, then compare the existing & proposed surfaces using terrian model explorer? Then run the reports? That's what we do.
    I really shouldn't answer a question with a question, huh?
    I could stop if I wanted to andy.manninen's Avatar
    2015-10
    @ _ork
    304
    At my work, for preliminary we just run a Gross cut/ fill. For final after we complete our grading plan we do the works on the surfaces, we add in all points, road grid, 3D polylines(for wall and unprofiled roads) and run multiple surface calculations. We make a subgrade correction surface that we make from plotting the locations of soil bore's and the depth of correction, we determine spoil areas and we determine where we can mine out good material. All in all, for final we end up with a Existing surface, a Final proposed surface, correction surface, and here are the weird ones, cut surface (taken from contours made from the gross grid volume, only in cut), a cut surface with control boundary and a finished grade surface with control boundary. With these surfaces we can interpolate the unadjusted correction from the site, the unadjusted good material, gross cut and gross fill. Then we figure in house pad hold downs and road hold downs. Its a long process but we have gotten very good results.
    :Cheers:
    Andrew Manninen
    CAD Manager
    The man who smiles when things go wrong has thought of someone to blame it on. - Robert Bloch
    Civil Engineering Moderator MHultgren's Avatar
    Central Iowa
    1,420
    Phil,
    I have done my quantities a few different ways. I have run my prelims using the subgrade approach while taking into account the fact that when they cut for subgrade, they have a 4:1 max slope (in these parts anyway) from the subgrade cut to the front of the pad. It took a couple times back and forth with the grading contractors to see why our numbers were so much different from their's. Some of them would only run the slope to 20' behind the ROW, while others would go to the pad. Then we would subtract the overex for each of the pads, figure in subsidence and shrinkage and take .5' off the entire site for 'Grubbing' and scarification.
    In other regoins, they just want the 'Raw' numbers, no transformations or adjustments. And then there are others that want you to include the Shrinkage adjustments directly into your output tables.
    Mark Hultgren
    Just a Lurker
    http://www.MKW-Ind.com
    Blog
    Socializing??
    2002-08
    Buckeye State
    137
    This is the kind of feedback I was looking for...Thanks guys!
    At times, it seems like we worry a little too much about earthwork quantities in our office. While it is plain to see that we can save our clients significant amounts of money by minimizing the amount of earthwork to be done, it does seem a bit extreme to concern ourselves with a minute amount of material (of course minute being a relative term). It is good to know that we are not the only ones that go to great lengths to calculate earthwork quantities.
  1. 2012: Earthwork reports
    By tRench_Indy in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2017-08-10, 10:19 AM
  2. Earthwork Quantities
    By CADDaddy in forum Revit Architecture - General
    Last Post: 2011-09-02, 01:06 PM
  3. Earthwork in Civil 3D
    By Jawwad Malik in forum AutoCAD Civil 3D - General
    Last Post: 2010-05-24, 03:05 AM
  4. HELP!!!!!! Earthwork Control
    By nilknarf23 in forum AutoCAD Civil 3D - Sections
    Last Post: 2009-11-23, 10:23 PM
  5. detail earthwork
    By sturner in forum Land Desktop - General
    Last Post: 2004-08-23, 08:46 PM
