Results 1 to 10 of 10
Thread: I want to edit a Block in place by double clicking on it
    2005-05
    111
    Question I want to edit a Block in place by double clicking on it
    I have set this up before but I can not remember what I did.
    I want to edit a block in place by double clicking on in. Now it is set to open the block edit tool window. How can I change that???
    0,0,0 The Origin
    8,570
    Default Re: I want to edit a Block in place by double clicking on it
    Setting DBLCLKEDIT to On may help you.
    9,805
    Quote Originally Posted by pangell
    Do you mean that it currently executes BEDIT, but that you want it to execute REFEDIT?
    What AutoCAD version?
    2001-11
    33
    Unhappy Re: I want to edit a Block in place by double clicking on it
    It does not sound like you can. The AutoCAD help file indicates that this is the standard method used for editing blocks. Do you not like using this new tool? You might try it and then you may find it useful, but there are some limitations. You could also Right-click the block and choose the in-place editing of the block.
    2005-05
    111
    Yes I want is to do and refedit when I double click on it. I am using adt 2007
    9,805
    Quote Originally Posted by glen.21464
    It all depends on the version of AutoCAD. That is why I asked above.
    In 2007, you can customize double-click actions.
    Active Member nickeshaffer's Avatar
    2006-01
    Spencer IA
    65
    I would also like to use REFEDIT instead of BEDIT when double clicking on a block...
    using ACAD 2006
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,104
    To prevent access to the Block Editor
    On the command line, enter blockedtlock.
    Enter 1, and then press ENTER.
    2006-01
    Spencer IA
    65
    Sweet, thanks much!
    2005-05
    111
    Smile Re: I want to edit a Block in place by double clicking on it
    Thank you all for the help
  1. AutoCAD 2009 - Double click MText to edit in place
    By kim.182466 in forum AutoCAD General
    Last Post: 2008-06-12, 08:45 AM
  2. Edit block in place
    By .chad in forum ACA General
    Last Post: 2007-04-18, 08:11 PM
  3. Double clicking to edit text - where are you?
    By Rico in forum AutoCAD General
    Last Post: 2006-12-18, 03:31 PM
  4. Replies: 1
    Last Post: 2006-05-12, 08:22 AM
  5. Double clicking to edit (attedit) not working
    By cmason in forum AutoCAD General
    Last Post: 2006-01-04, 04:45 PM
