I attach a rvt file here.
inside it, there are two slabs drawn which are on different floor height.
so I created a slab edge (thickening) to connect them together,
very common case in drop slab.
My question is :
no matter I join or not join the three objects (2 slabs + 1 slab edge),
under wireframe mode, all hidden lines indicating object below shown
normally. (because I have set slab edge always be hidden in object style)
But under hidden mode, all lines below disappear.
As you know if I export rvt model to dwg, and I choose wireframe,
all lines would be overlapped in the output file, while export in
hidden mode would clean up all duplicating lines.
so can anyone suggest a good solution for this problem ?
