Thread: Fascia
    All AUGI, all the time ford347's Avatar
    2005-01
    Oroville, CA
    874
    Default Fascia
    Is there a way to get the roof or a layer of a roof to extend over the fascia like it would in real life? I always have these fascia runs in my elevations that look terrible and I end up just using line work and the paint tool to get rid of them. I've tried using the offset horizontally and vertically tool within the fascia tool, but that screws up all the miters at the corners, well, they don't miter.
    Thanks.
    All AUGI, all the time Arnel Aguel's Avatar
    2003-05
    Philippines
    577
    Default Re: Fascia
    How I wish that we could have the same function that we have for the composite wall where we can unlock the layer and extend it to where we want it to be.
    I guess we should put that in the wish list item.
    All AUGI, all the time eddy.lermytte's Avatar
    Belgium
    554
    Default Re: Fascia
    Josh
    you can't extent layers of a roof or floor.
    In that case I create 2 roofs one on top of the other. One for the roofs structure and one for the top for example.
    All AUGI, all the time christo4robin's Avatar
    2003-05
    Boulder, Colorado
    681
    Default Re: Fascia
    You've got a couple of options...
    1. Model your structural roof and your finish roof as two seperate objects having nearly identical footprints. Then you can control sheathing and shingles (or whatever) as you need to for those real live overhangs. Scheduling can be the problem in this scenario.
    2. Fascias are profile based and profiles can contain detail components. You could create a custom fascia profile that provides the extension you are looking for. Material definitions are the problem in this scenario, but you can get it to display well in larger scale sections/details.
    3. Model your "extension" as a separate, donut type roof object - it will be very thin in plan, 1" or whatever you desire, and it will be only those layers that extend. Use Join Geometry to eliminate the line b/t the two. If you want to keep it all constrained together, use pick/lock for the join line (while in sketch mode) and then offset this line the appropriate dimension and then add locked dimensions for the outer line. That way if the primary roof changes, the secondary will update as well. This is probably the best way from the perspective of scheduling, management, and graphics.
    Cheers!
    2005-01
    Oroville, CA
    874
    Default Re: Fascia
    Thanks you guys!!
    Really helped!!
    Josh
  1. Roof fascia - "Can't create Fascia"
    By tomm in forum Revit Architecture - General
    Last Post: 2014-05-14, 04:05 PM
  2. fascia
    By ntnik in forum Revit Architecture - General
    Last Post: 2008-07-17, 03:48 PM
  3. roof fascia
    Last Post: 2008-04-23, 08:22 PM
  4. Fascia Boards
    By harkeychad in forum Revit Architecture - General
    Last Post: 2008-02-06, 12:58 PM
  5. Roof Fascia
    By max in forum Revit Architecture - General
    Last Post: 2005-03-02, 04:09 PM
