Thread: DWF Composer
    Member tvanniekerk's Avatar
    2005-06
    Johannesburg, South Africa
    34
    Default DWF Composer
    I downloaded the DWF composer trial to test the markup function.
    It works fine to mark up a drawing, but once i link the marked updrawing set back into Revit, there seems to be a scale problem, because the markup annotations are several times larger than the original sheet it was marked up on, and it looks like a factor of 100x or similar.
    do I miss something during the conversion, or what must I do.
    Theo
    2005-05
    TX
    447
    Default Re: DWF Composer
    Make sure you are linking back into a sheet. If you link back into a view, it doesn't work. And, I believe the sheet view must be the one you export.
    2003-08
    Vancouver, BC Canada
    3,392
    Also be sure you are using the most current build of Revit
    Refer ot this thread http://forums.augi.com/showthread.ph...build+download
    ____________________________
    Dimitri Harvalias LEED AP
    Summit BIM Consulting
    BIMblog.ca
    I was never just a CAD monkey, so I refuse to be a BIMpanzee!
    A BIM without the 'I' is just a BM - those in the medical profession know what that amounts to
  1. 2011: Mur Composer
    By lucos in forum Revit Architecture - Général
    Last Post: 2011-02-14, 03:46 PM
  2. Customize DWF Composer
    By BCrouse in forum Design Review - General
    Last Post: 2005-02-18, 12:55 PM
  3. 3D model in composer
    By stewmeat101 in forum Design Review - General
    Last Post: 2005-02-09, 05:56 PM
  4. DWF Composer
    By David Sammons in forum Revit Architecture - General
    Last Post: 2004-06-07, 03:42 PM
