Thread: Nested Door Panel in Curtain Wall Door Family
    2001-07
    Phoenix, AZ
    1,003
    Default Nested Door Panel in Curtain Wall Door Family
    I'm trying to nest the door panel I used in my standard doors into a curtain wall door family and link the parameters so that as the panel gets bigger the door panel responds... and I'd like to be able to modify the swing in 3D (nothing new here in regards to doors).
    So far I'm not making much progress.
    It seems that I'm not able to place a parameter to control the width of the panel, for example (which does make a certain amount of sense). When I place the parameter and try and flex the family I get an error. And if I can't get this parameter to work then I can't link the nested family's parameter to it...
    The only solution I have is to recreate all of the geometry I want native to the file and I'd rather not do that if I don't have to.
    Any ideas?
    [edit] And even if I do make the doors directly in the family how do I get them to schedule as a pair of doors instead of as one big wide one? My typical double doors schedule as a pair of 3'-0" instead of as a single 6'-0".
    All AUGI, all the time Elmo's Avatar
    2005-04
    South Africa
    959
    Default Re: Nested Door Panel in Curtain Wall Door Family
    It won't happen. You will have to manually change it. This is simply because a curtain wall door doesn't have any dimensions in it. The only way you'll get it to work is if you create the panel inside the curtain wall door family.
    2003-05
    5,153
    If you set your curtain wall panel size to the width / height required for your door , you can place a solid wall segment in lieu of the CW panel and then place your door in that panel.
    2001-07
    Phoenix, AZ
    1,003
    Here's what I ended up doing...
    I took my typical Door Panel family and recategorized it as a Generic Model and then made the Width and Height parameters Instances. I loaded it into a Door-Curtain Wall family and align-locked the edges to the Reference Planes. I did the same thing for the 2D Swing family in plan and added and linked the necessary parameters. Works fine!
    As to the scheduling issue with double doors I decided to add a Type Comment noting that the door panel was half of the listed width and added this to my schedule. Not ideal but "technically" okay...
    2007-03
    Salt Lake City
    360
    Quote Originally Posted by beegee View Post
    Great tip.(makes me happy as a cloud) Still might have to create a door family that has the correct frame or lack thereof to look proper in a storefront or curtain wall system, but it is an nice way to use door families that you've already created and not have to mess with the separate curtain door families.
  1. Curtain wall sliding door panel
    By jeff.95551 in forum Revit Architecture - Families
    Last Post: 2016-03-12, 03:35 PM
  2. Curtain Wall door panel family
    By patricks in forum Revit Architecture - Families
    Last Post: 2008-04-17, 05:26 PM
  3. Symbolic lines on Curtain panel door family
    By tim.101799 in forum Revit Architecture - Families
    Last Post: 2007-06-07, 05:18 PM
  4. Door Tags remain after Door Curtain Panel Switch
    By bowlingbrad in forum Revit Architecture - General
    Last Post: 2006-05-04, 04:00 PM
  5. Curtain Wall Door Panel
    By ajayholland in forum Revit Architecture - Families
    Last Post: 2003-10-08, 03:27 PM
