This program currently works fine, the problem is, I can zoom out and watch each and every item move one at a time.
I would like it to run much faster, the drawing it is used on is also attached.
We use Eagle Point to create our cross section sheets and they have a bug in their latest patch, so I need a temporary fix until they fix their screw up.
(defun c:xs (/ xsinfo xsobj)
(setq xsinfo
(ssget
"_X"
(list (cons 8 "DESIGNEARTHWORK,CL_ELEVATIONS,SLOPES,CL_ORIG_ELEV,STATIONS,DES_SUBBASE,DES_AGGBASE,DES_RUBBLIZED,DES_BASE,DES_LEVELING,DES_SHOULDER,ORIG_SURFACE,DES_WEARING,ANN_ELEV_OFF")
(while (setq xsobj (ssname xsinfo 0))
(command "move" xsobj "" <A href="mailto:"0,0" "@0.4777,0.4074">"0,0" "@0.4777,0.4074")
(ssdel xsobj xsinfo)
) ;end while
) ;end defun
