Thread: How do you get a simple handrail?
    2003-04
    236
    Default How do you get a simple handrail?
    I have extended my handrail 12 in past the ramp and I cannot get rid of the vert baluster.
    Any help greatly appreciated
    2004-08
    107
    Default Re: How do you get a simple handrail?
    two ways.
    1. do not extend the HR line at all: use a HANDRAIL EXTENSION w/out POST piece as the end "post"
    (you can download these all over the place; Autodesk CONTENT distribution has 'em)
    2. moneky around with your baulstrade spacing from end
    (I said MONKEY cause I have a feeling that a primate could do this second method faster then I can- it is a bit unnerving, but a little testing with the spacing will do it)
    My $.02
    Christopher M. Ryan
    Principal
    4dPerspective
    I could stop if I wanted to Rhythmick's Avatar
    2004-03
    Colorado
    323
    Select the handrail, check the properties - Edit - Baluster Placement - and set the Baluster Families to "none" for main pattern and posts.
    Mike Lenz
    Genuine Homes Corp
    "Gone Fishing"
  1. simple lables on simple entities
    By Maverick91 in forum AutoCAD Civil 3D - General
    Last Post: 2010-09-22, 09:38 PM
  2. Changing a Handrail
    By peter_guthrie in forum Revit Architecture - General
    Last Post: 2009-12-14, 08:45 PM
  3. revit - simple handrail
    By seth.193005 in forum Revit Architecture - General
    Last Post: 2009-11-10, 07:49 PM
  4. Cut Handrail
    By bclarch in forum Revit Architecture - General
    Last Post: 2005-05-17, 08:18 PM
