Hi
when I make surface by any method like cross section and rail, the result is surface which it has normal line, my question is : can I change direction of that surface? if it has direction to up , can I change it to down?
thank you for your help
Hi
Old skewl question. It's been a long time since I've messed with MDT surfaces (and I wasn't that good then). I don't have MDT right in front of me, but if I remember right I think you can edit the surface and 'Flip Normal'.Originally Posted by ibn_seeena
You might be able to search the help system for 'Flip Normal' too.
Hope this helps
Jonathan Landeros
KETIV Technologies
Orange County, California.
I've got a blog: www.inventor-tales.blogspot.com
“We have now left Reason and Sanity Junction.Next stop, Looneyville.” -Bob the Skull in the Dresden Files
thank you jonathan I tried in : surface , edit surface, then ajust normals.
thank you very much indeed
Hi there,
If possible can you tell me what is the "Truncate" option in "ameditsf" or edit surface dialog box. I read through HELP but i was not able to understand it
pleeaaaaase
Ganesh
