Thread: How to Create Access table data to AutoCAD VBa Combo box data
    2005-02
    95
    Default How to Create Access table data to AutoCAD VBa Combo box data
    I am making database program, my datas are in the .mdb file,
    I want to select markers from combobox in AutoCAD VBA program, then it set automatically other parameters. How can be done.
    When we change in the combo box title and other parameters will change, for that how to create the access table data to AutoCAD VBA combo box data.
    Turlock, CA
    6,420
    Default Re: How to Create Access table data to AutoCAD VBa Combo box data
    You will need to use ADO or DAO to talk to Access. Do you know anything about those? If not, you will need to do some research on those. Access help file has info on DAO. MSDN has info on both. If you are just starting out, learn ADO.
    C:> ED WORKING....
    LinkedIn
    2002-02
    Kansas
    487
    ?? do you have access
    ?? were in the drawing is this data to be saved if save in the drawing
    I do some like this that set up are cross section in drawing but open access to show and work with the data file and then update the cross section in the drawing use vba in access.
  1. Replies: 2
    Last Post: 2009-02-10, 02:25 PM
  2. Replies: 1
    Last Post: 2007-04-07, 12:39 PM
  3. Insert Block, allow user to enter data, then have the data placed in a Table
    By thomas.stright in forum Dynamic Blocks - Technical
    Last Post: 2006-08-11, 02:40 PM
  4. How to create a combo box data
    By avinash00002002 in forum VBA/COM Interop
    Last Post: 2006-06-08, 05:47 AM
  5. Linking AutoCAD Object Data Table to Access table
    By m.storey in forum AutoCAD Map 3D - General
    Last Post: 2006-05-02, 02:54 PM
