Results 1 to 7 of 7
Thread: How to use Tables in AutoCAD 2006
    2004-07
    7
    Question How to use Tables in AutoCAD 2006
    We use excel and a 3rd party to insert schedules. We don't have enough licenses for everyone to do the inserting with the 3rd party program. Panel schedules, long equipment lists and some lengthy word documents
    I'd like to be able to use the table for the replacement of doing our schedules in excel and word documents..
    Thank you
    2001-03
    13,499
    Default Re: How to use Tables in AutoCAD 2006
    Hi
    Please note I have *moved* this thread from the CAD Mgmt. General forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
    2001-03
    13,499
    Quote Originally Posted by rtollefsen
    Hi
    Can you please explain, exactly what you would like to know about Tables eg What do you want to achieve...
    Have a good one, Mike
    2004-07
    7
    Unhappy Re: How to use Tables in AutoCAD 2006
    Hi, Thanx for moving my post to the correct location.
    The table is a completly new animal to me ~ ~
    Can a filled in schedule be made, saved and inserted into a dwg. ~ then can this same schedule be inserted into a different job be revised and not affect the schedule in the first job?
    I don't want to use excel to make schedules.
    Houston
    7,519
    A TABLE entity is just that --- a different entity type. You can create Table Styles (like textstyles or dimstyles) for apperance, but the TABLE itself is an AutoCAD entity. You create it and populate it inside of AutoCAD.
    Yes, there is no table linking.
    2001-03
    13,499
    Hi
    No worries...
    Hopefully you will find some of the information contained with the following links, helpful / useful...
    RE: Table Formula Formats
    RE: plant list
    RE: Extract Attribute Data into a Table
    Enter text in a Table and have a Field based off the text placed elsewhere
    Get doors and tags to a schedule in AutoCAD 2006?
    Count the number of Blocks in a drawing file
    2004-07
    7
    Is the tables in 2006 really worth it right now and/or any better in '07??? If there's a problem with getting the correct text, not getting different cell sizes, etc.
  1. EATTEXT to Tables in ADT 2005 v's ADT 2006
    By tedg in forum ACA General
    Last Post: 2006-09-22, 11:47 AM
  2. AutoCAD 2006 - Minus cells between two tables
    By tyeelaw13 in forum AutoCAD Tables
    Last Post: 2006-09-14, 12:47 AM
  3. Replies: 4
    Last Post: 2006-04-28, 01:38 PM
  4. Replies: 2
    Last Post: 2006-03-17, 11:14 PM
  5. Replies: 5
    Last Post: 2006-03-13, 06:27 PM
