Thread: Polygon Viewport - Using Maximize Viewport feature causes problems
    Member Shoey's Avatar
    2004-10
    Bradford, England
    33
    Default Polygon Viewport - Using Maximize Viewport feature causes problems
    Hi all,
    Has anybody had this problem?
    2005
    Working in a drawing with several layouts.
    Working on one of these layouts.
    Layout contains 1 polygon viewport.
    Pressed the maximize viewport button to enable max view of viewport.
    Did a few commands, erase, move, hatch etc.
    Pressed the maximize button to toggle back to paper space.
    Did nothing.
    Pressed again.
    Did nothing.
    Pressed the MODEL / PAPER space button to left of the maximize viewport button.
    Lost all my paper space elemets, border, notes key etc. (see attached image).
    Tried exiting / entering AutoCAD, re-boot, recover etc but to no avail.
    Had to re-insert the layout again from an autosave file in the end.
    Anyone had problems like this with the maximize viewport button?
    Regards
    Shoey
    2001-03
    13,499
    Question Re: Polygon Viewport - Using Maximize Viewport feature causes problems
    Hi
    Does this issue / problem occur in all drawing files containing Polygonal Viewports ?
    Or just the odd isolated drawing file ?
    Is it possible to post a drawing file that exhibits such behaviour, so we can take a look at the issue / problem, first-hand ( so-to-speak ).
    Have a good one, Mike
    2004-10
    Bradford, England
    33
    Default Re: Polygon Viewport - Using Maximize Viewport feature causes problems
    Hi Mike, Hows tricks?
    This is the first time i have experienced this happening.
    Will it do it again? I dont know.
    I will post the drawing file if i this happens again and will make a record
    of events leading up to it very carefully!
    Cheers
    Shoey
  1. 2012: Maximize Viewport/Linetypes
    By mhannan.100562 in forum AutoCAD General
    Last Post: 2011-07-20, 03:33 PM
  2. maximize viewport
    By dcochrane757156 in forum AutoCAD Tips & Tricks
    Last Post: 2010-02-12, 09:37 PM
  3. Double Click Viewport to Maximize
    By sschwartz in forum AutoCAD Tips & Tricks
    Last Post: 2007-01-23, 08:05 PM
  4. Maximize Viewport
    By chadwickt in forum AutoCAD General
    Last Post: 2005-03-14, 01:45 PM
