I am searching a lisp routine which can convert blocks (with elevation) into LDD points, any help? Thanks in advance
What kind of blocks? Block with attribute that holds the elevation? Just a block of something inserted at the elevation? What version LDD?
Try ATTEXT or EATTEXT to get your points in a file you can import into LDD. You'll have to create a template file matching the information in the blocks you want converted to the point format you're using in LDD. Then freeze the old point block layers.
Tom Beauford P.S.M. - Civil 2013 on Windows 7 Pro
Design Analysis - Leon County Public Works/Engineering
Ph# (850)606-1516
Miff,
LDD 2004, the blocks are “standard” blocks inserted at an elevation (no attributes).
Tom,
“EATTEXT” seems to be working for me, thanks…
I have created a routine that creates points in the same location that the insertion point of a block! (elevation included)
See also: PNTCONV.LSP at http://www.dotsoft.com/freestuff.htm.
It won't do a direct conversion, but will create an PNEZD ASCII file which you can import.
Thanks you have all been very helpful.
