Results 1 to 9 of 9
Thread: interior elevation
    2004-08
    56
    Default interior elevation
    We are still running v8.1 so the answer to this question might be to go to v9.
    I have interior elevations of a series of rooms with different ceiling heights (see attached). Is there a way of making the crop region anything other than a rectangle so I'm not showing what appears to be a building section? The only way I know to do this is with a solid fill above the elements higher than the ceilings, but this is a real pain.
    thanks.
    All AUGI, all the time Justin Marchiel's Avatar
    2004-07
    Penticton, B.C., Canada
    954
    Default Re: interior elevation
    Nope, no way yet. This is something that i have struggled with as well. Hopefully it will be addressed in the future.
    Justin
    2005-07
    172
    sorry... it does stink - you can lock the filled region to the ceiling in the view though I believe, so atleast it will manage itself a little better....
    -dp
    I could stop if I wanted to Baldwin_4-6-0's Avatar
    2004-02
    384
    you can get creative with blanking things out with empty filled regions using invisible lines.
    Someday I hope shaped crop regions are possible.
    100 Club Chris DiSunno's Avatar
    2004-10
    East Hampton, NY
    171
    It is so tedious, but we make a white filled region with a heavy line for the edge of the elevation and an invisible line for the outside.
    I wish this could be automated within the program!!! So many other things work so well.
    Active Member guy.messick825831's Avatar
    2005-06
    84
    Make sure your filled regions use "No Pattern" instead of solid white. Export to .dwg to see why!
    2006-11
    2
    I have a similar situation in my project. I'm using Revit Architecture 2009. Is there any change to the crop regions, or do I still need to use the filled regions to create the desired crop region shape?
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,439
    In 2009 you will use the masking region tool with a heavy lineweight.
    Scott D. Brown, AIA
    Project Coordinator | Director of Building Information Modeling
    HHCP.com
    2006-11
    2
    Smile Re: interior elevation
    Thanks, Scott!
    That works perfectly!
  1. Interior elevation key
    By mrdavie in forum Revit Architecture - General
    Last Post: 2011-04-06, 08:44 PM
  2. Jog In Interior Elevation
    By TerribleTim in forum Revit Architecture - General
    Last Post: 2010-08-12, 06:41 PM
  3. Interior Elevation Tag
    By kshawks in forum Revit Architecture - General
    Last Post: 2009-04-08, 07:28 PM
  4. Interior Elevation Box
    By sjsl in forum Revit Architecture - General
    Last Post: 2007-08-02, 11:52 PM
  5. Interior Elevation Tag
    By .chad in forum Dynamic Blocks - Technical
    Last Post: 2006-08-09, 08:35 PM
