Results 1 to 8 of 8
Thread: Non Continuous Linetype used with Sketch command looks Continuous no matter what
    ATP Recruiter Li'l Crys's Avatar
    2004-11
    88
    Default Non Continuous Linetype used with Sketch command looks Continuous no matter what
    I have search and searched and searched and I cannot find my answer.
    Ok, so I am trying to figure out how to make the linetype actuallly show up on a sketch line. ie, freehand <sketch> the outline for a river. Try to change the ltype to a water course line (____ . . . ____) and it appears continuous. I understand that it's beacuse the line segments for the sketch are too small but what is the workaround, or is there one.
    Thanks
    100 Club cholmes's Avatar
    2003-02
    Omaha, NE
    198
    Default Re: Non Continuous Linetype used with Sketch command looks Continuous no matter what
    Ok first step, convert the sketch lines to plines and join them, (or set skpoly to 1 before sketching the line to automatically create a pline)
    Next, set plinegen to 1. This wil make the sketched lines look ok, but it may make other plines look goofy (at corners for example)
    That should do it!
    Edit: However, it still seems to not work the greatest if your sketch segments are really small. May need some more experimentation.
    Also, the plinegen only affects plines created after setting it. However, you can draw one, and then match properties on the others, or select them all and change in the properties palette (linetype generation)
    2004-11
    88
    Quote Originally Posted by cholmes
    That should do it!
    HAHAHAHA Genius. Thank you so much. I have spend half the day looking for that!
    0,0,0 The Origin
    8,570
    Also, do you really need to use Sketch?
    Have you tried drawing with Pline and fitting curves (with Pedit) afterwards?
    When I was tracing maps I soon gave up with Sketch; even with Skpoly set.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Quote Originally Posted by jaberwok
    Sketch seems too cumbersome.
    0,0,0 The Origin
    8,570
    Quote Originally Posted by Opie
    How to convert your pc into an expensive Etch-a-Sketch.
    2005-07
    2,356
    Post Re: Non Continuous Linetype used with Sketch command looks Continuous no matter what
    The only time I use the sketch command is when embelishing elevations, ie. adding trees or vegetation in a hand draw style.
    I didn't know about the skpoly sys var though.
    2004-08
    Iron Station, NC
    3,198
    we use it for drawing proposed contours, we have a mouse that is shaped like a pen, it works great for this, alot easier than a mouse.
  1. linetype of cirlces only displaying as continuous
    By aletourneau in forum AutoCAD General
    Last Post: 2017-08-04, 04:52 PM
  2. Non Continuous Linetype Beginning and Ending Segments
    Last Post: 2015-10-08, 06:49 PM
  3. make linetype continuous
    By gingermick in forum AutoLISP
    Last Post: 2009-06-01, 10:54 PM
  4. Linetype Scale Factor - Hidden Line remains continuous
    By Detsenira in forum AutoCAD General
    Last Post: 2006-09-01, 02:59 PM
  5. Replies: 6
    Last Post: 2006-03-31, 06:58 PM
