Please see attached drawing file in previous post for an example of my exact situation.
Thank you for your time.
Now only I came to know the real meaning of that sentence. It's 2.30 a.m hereOriginally Posted by danderson.71652
Nice to hear that.I did not mean to rush or sound impatient with the crickets comment, I was trying to add a little humor to my ignorance.
I think it can be done by keeping handles of the objects in the array. But not sure about that. I have to experiment with that. Again you have to be patient with meI believe this is exactly the direction I am going...I just need to incorporate it into my exiting code
Please look at the line "' PLEASE READ THIS COMMENT" in the code.
'sorting goes here into array, then sort, then back into array, then into a new selectionset
'can this be done?
har!s
Oh, I do not have much to add, my brain is spent. I can wait. Thank you so much for you time, I have learned a great deal with this effort.
Thank you again
Hi Danderson,
I have rewritten my program to incorporate the selection set. Try how the code works now...
HTHCode:Sub SortTextByPos() On Error Resume Next Dim objTxt As AcadText Dim objSSet As AcadSelectionSet Dim gpCode(0) As Integer: Dim dataVal(0) As Variant Set objSSet = ThisDrawing.SelectionSets.Add("TxtSet1") gpCode(0) = 0: dataVal(0) = "Text" ReSelect: objSSet.SelectOnScreen gpCode, dataVal If objSSet.Count <> 0 Then Dim TxtPnt As Variant Dim arTxtPnts() As Variant Dim TxtBasePnt(0 To 1) As Double Dim iDim As Integer iDim = 0 ReDim Preserve arTxtPnts(objSSet.Count - 1, 2) For Each objTxt In objSSet If objTxt.Alignment = acAlignmentLeft Then TxtPnt = objTxt.InsertionPoint Else TxtPnt = objTxt.TextAlignmentPoint End If TxtBasePnt(0) = TxtPnt(0): TxtBasePnt(1) = TxtPnt(1) arTxtPnts(iDim, 0) = TxtPnt(0) arTxtPnts(iDim, 1) = TxtPnt(1) arTxtPnts(iDim, 2) = objTxt.Handle iDim = iDim + 1 Next arTxtPnts = SortArrayByCoords(arTxtPnts) Dim arTxtObjs() As AcadText Dim objSortedSSet As AcadSelectionSet ReDim arTxtObjs(UBound(arTxtPnts)) Set objSortedSSet = ThisDrawing.SelectionSets.Add("SS_Text1") For i = 0 To UBound(arTxtPnts) Set arTxtObjs(i) = ThisDrawing.HandleToObject(arTxtPnts(i, 2)) Next objSortedSSet.AddItems arTxtObjs '<-- Display values for checking --> Dim strOP As String For Each objTxt In objSortedSSet strOP = strOP & objTxt.TextString & vbCrLf Next MsgBox strOP objSortedSSet.Highlight True '<-- End display --> objSortedSSet.Delete objSSet.Delete End If If Err.Number <> 0 Then MsgBox Err.Description Err.Clear End If End Sub Function SortArrayByCoords(ByVal arSource As Variant) Dim i As Integer Dim j As Integer Dim dblTmpVal(2) For i = UBound(arSource) To LBound(arSource) Step -1 For j = LBound(arSource) + 1 To i '<-- Check for the X coordinates first and if they are equel - '<-- compare the the Y coordinates --> If ( _ (arSource(j - 1, 0) > arSource(j, 0)) _ Or ( _ (arSource(j - 1, 0) = arSource(j, 0)) _ And _ (arSource(j - 1, 1) < arSource(j, 1)) _ ) _ ) Then dblTmpVal(0) = arSource(j - 1, 0) dblTmpVal(1) = arSource(j - 1, 1) dblTmpVal(2) = arSource(j - 1, 2) arSource(j - 1, 0) = arSource(j, 0) arSource(j - 1, 1) = arSource(j, 1) arSource(j - 1, 2) = arSource(j, 2) arSource(j, 0) = dblTmpVal(0) arSource(j, 1) = dblTmpVal(1) arSource(j, 2) = dblTmpVal(2) End If Next j Next i SortArrayByCoords = arSource End Function
har!s
I am almost complete with the implementation, I will post the code shortly!
I have added the code into mine. The only thing left to figure out is Mtext.
In the example drawing file I have, one table's entities are just Text, and one Text and Mtext.
The code work flawless on just TEXT.
This is amazing, and congratulations on a fine job. I can't thank you enough.
See attached drawing.
Dan
Code:Option Explicit Sub FieldsToTableFinal() Dim oSsets As AcadSelectionSets Dim oSset As AcadSelectionSet Dim oSset2 As AcadSelectionSet Dim oTable As AcadTable Dim oText As AcadText Dim j, k, l, m As Long Dim i, n As Integer Dim FilterType(3) As Integer Dim FilterData(3) As Variant Dim insPt As Variant Dim tmpStr As String Dim basePnt As Variant Dim celltxtchk As String Dim oMText As AcadMText Dim SSetSort As Variant FilterType(0) = -4 FilterData(0) = "<or" FilterType(1) = 0 FilterData(1) = "TEXT" FilterType(2) = 0 FilterData(2) = "MTEXT" FilterType(3) = -4 FilterData(3) = "or>" On Error Resume Next ThisDrawing.SelectionSets.Item("FieldsToTable").Delete ThisDrawing.SelectionSets.Item("FieldsToTablesorted").Delete Set oSset = ThisDrawing.SelectionSets.Add("FieldsToTable") Set oSset2 = ThisDrawing.SelectionSets.Add("FieldsToTablesorted") On Error GoTo ErrMsg oSset.SelectOnScreen FilterType, FilterData If oSset.Count <> 0 Then Dim objTxt As AcadText Dim objSSet As AcadSelectionSet Dim TxtPnt As Variant Dim arTxtPnts() As Variant Dim TxtBasePnt(0 To 1) As Double Dim iDim As Integer iDim = 0 ReDim Preserve arTxtPnts(oSset.Count - 1, 2) For Each objTxt In oSset If objTxt.Alignment = acAlignmentLeft Then TxtPnt = objTxt.InsertionPoint Else TxtPnt = objTxt.TextAlignmentPoint End If TxtBasePnt(0) = TxtPnt(0): TxtBasePnt(1) = TxtPnt(1) arTxtPnts(iDim, 0) = TxtPnt(0) arTxtPnts(iDim, 1) = TxtPnt(1) arTxtPnts(iDim, 2) = objTxt.Handle iDim = iDim + 1 Next arTxtPnts = SortArrayByCoords(arTxtPnts) Dim arTxtObjs() As AcadText 'Dim objSortedSSet As AcadSelectionSet ReDim arTxtObjs(UBound(arTxtPnts)) 'Set objSortedSSet = ThisDrawing.SelectionSets.Add("SS_Text1") For i = 0 To UBound(arTxtPnts) Set arTxtObjs(i) = ThisDrawing.HandleToObject(arTxtPnts(i, 2)) Next oSset2.AddItems arTxtObjs i = oSset2.Count ThisDrawing.Utility.GetEntity oTable, basePnt, "Select Table to fill-out:" k = oTable.Columns If k <> 2 And k <> 5 Then Exit Sub End If j = i k l = 0 n = 0 For l = 0 To k - 1 For m = 3 To j + 2 celltxtchk = oSset2.Item(n).ObjectName If celltxtchk = "AcDbMText" Then Set oMText = oSset2.Item(n) tmpStr = CStr(oMText.ObjectID) End If If celltxtchk = "AcDbText" Then Set oText = oSset2.Item(n) tmpStr = CStr(oText.ObjectID) End If tmpStr = "%<AcObjProp Object(%<_ObjId " & tmpStr & _ ">%).TextString f " & "" & "%bl2" & "" & ">%" oTable.SetText m, l, tmpStr n = n + 1 'oTable.Update Next Next oSset2.Clear oSset2.Delete oSset.Clear oSset.Delete Set oSset2 = Nothing Set oSset = Nothing Set oSsets = Nothing Set oTable = Nothing Exit Sub End If ErrMsg: MsgBox Err.Description End Sub Sub SortTextByPos() Dim objTxt As AcadText Dim objSSet As AcadSelectionSet Dim gpCode(0) As Integer: Dim dataVal(0) As Variant Set objSSet = ThisDrawing.SelectionSets.Add("TxtSet") gpCode(0) = 0: dataVal(0) = "Text" ReSelect: objSSet.SelectOnScreen gpCode, dataVal If objSSet.Count <> 0 Then Dim TxtPnt As Variant Dim arTxtPnts() As Variant Dim TxtBasePnt(0 To 1) As Double Dim iDim As Integer iDim = 0 ReDim Preserve arTxtPnts(objSSet.Count - 1, 2) For Each objTxt In objSSet If objTxt.Alignment = acAlignmentLeft Then TxtPnt = objTxt.InsertionPoint Else TxtPnt = objTxt.TextAlignmentPoint End If TxtBasePnt(0) = TxtPnt(0): TxtBasePnt(1) = TxtPnt(1) arTxtPnts(iDim, 0) = TxtPnt(0) arTxtPnts(iDim, 1) = TxtPnt(1) arTxtPnts(iDim, 2) = objTxt.TextString iDim = iDim + 1 Next arTxtPnts = SortArrayByCoords(arTxtPnts) '<-- Display values for checking --> Dim strOP As String strOP = strOP & "X Coordinate" & vbTab & vbTab & "Y Coordinate" & _ vbTab & vbTab & "Text" & vbCrLf strOP = strOP & String(22, "-") & vbTab & vbTab & String(22, "-") & _ vbTab & vbTab & String(5, "-") & vbCrLf For i = 0 To UBound(arTxtPnts) strOP = strOP & arTxtPnts(i, 0) & vbTab & vbTab & arTxtPnts(i, 1) & _ vbTab & vbTab & arTxtPnts(i, 2) & vbCrLf Next MsgBox strOP '<-- End display --> objSSet.Delete End If End Sub Function SortArrayByCoords(ByVal arSource As Variant) Dim i As Integer Dim j As Integer Dim dblTmpVal(2) For i = UBound(arSource) To LBound(arSource) Step -1 For j = LBound(arSource) + 1 To i '<-- Check for the X coordinates first and if they are equel - '<-- compare the the Y coordinates --> If ( _ (arSource(j - 1, 0) > arSource(j, 0)) _ Or ( _ (arSource(j - 1, 0) = arSource(j, 0)) _ And _ (arSource(j - 1, 1) < arSource(j, 1)) _ ) _ ) Then dblTmpVal(0) = arSource(j - 1, 0) dblTmpVal(1) = arSource(j - 1, 1) dblTmpVal(2) = arSource(j - 1, 2) arSource(j - 1, 0) = arSource(j, 0) arSource(j - 1, 1) = arSource(j, 1) arSource(j - 1, 2) = arSource(j, 2) arSource(j, 0) = dblTmpVal(0) arSource(j, 1) = dblTmpVal(1) arSource(j, 2) = dblTmpVal(2) End If Next j Next i SortArrayByCoords = arSource End Function
Further Testing, I didn't get MText implemented yet....back to the drawing board
Thanks again,
Dan
Completed code:
Code:removed didnt work
What Zoomharis has done here is what's called a "Bubble sort" in computer science. It is one of the simplest sorting algorithms to understand, and it has the extra advantage on not requiring additional computer memory. I use it in a number of my programs, one of which sorts by the y-coordinate of a block.
You can Google "bubble sort" and get alot of additional information on it. Some sites will have code you can clip. You will also get info on other algorithms for sorting. It turns out that the bubble sort is the slowest of them all. If you were sorting all IRS tax returns by social security number, you would use a shell sort or a quick sort. These are created by mathematicians and are thousands times faster than the bubble sort.
Why VBA doesn't have some kind of built in sort is a mystery. It would certainly make a lot of our lives easier.
Wish list request??
True, check out this little Gem. All I did was compile the code.
It is a graphical comparison of various sorting methods that you can test.
Hi Dan,Originally Posted by danderson.71652
I have solved the MText issue in the latest modification. Please have a look at it.
Please incorporate it with your code and give me a feedback if possible.Code:Sub SortTextByPos() On Error Resume Next Dim objTxt Dim objSSet As AcadSelectionSet Dim gpCode(3) As Integer: Dim dataVal(3) As Variant Set objSSet = ThisDrawing.SelectionSets.Add("TxtSet") gpCode(0) = -4 dataVal(0) = "<or" gpCode(1) = 0 dataVal(1) = "TEXT" gpCode(2) = 0 dataVal(2) = "MTEXT" gpCode(3) = -4 dataVal(3) = "or>" objSSet.SelectOnScreen gpCode, dataVal If objSSet.Count <> 0 Then Dim TxtPnt As Variant Dim arTxtPnts() As Variant Dim TxtBasePnt(0 To 1) As Double Dim iDim As Integer iDim = 0 ReDim Preserve arTxtPnts(objSSet.Count - 1, 2) For Each objTxt In objSSet If TypeOf objTxt Is AcadMText Then TxtPnt = objTxt.InsertionPoint ElseIf objTxt.Alignment = acAlignmentLeft Then TxtPnt = objTxt.InsertionPoint Else TxtPnt = objTxt.TextAlignmentPoint End If TxtBasePnt(0) = TxtPnt(0): TxtBasePnt(1) = TxtPnt(1) arTxtPnts(iDim, 0) = TxtPnt(0) arTxtPnts(iDim, 1) = TxtPnt(1) arTxtPnts(iDim, 2) = objTxt.Handle iDim = iDim + 1 Next arTxtPnts = SortArrayByCoords(arTxtPnts) Dim arTxtObjs() As AcadEntity Dim objSortedSSet As AcadSelectionSet ReDim arTxtObjs(UBound(arTxtPnts)) Set objSortedSSet = ThisDrawing.SelectionSets.Add("SS_Text") For i = 0 To UBound(arTxtPnts) Set arTxtObjs(i) = ThisDrawing.HandleToObject(arTxtPnts(i, 2)) Next objSortedSSet.AddItems arTxtObjs '<-- Display values for checking --> Dim strOP As String For Each objTxt In objSortedSSet strOP = strOP & objTxt.TextString & vbCrLf Next MsgBox strOP objSortedSSet.Highlight True '<-- End display --> objSortedSSet.Delete objSSet.Delete End If If Err.Number <> 0 Then MsgBox Err.Description Err.Clear End If End Sub Function SortArrayByCoords(ByVal arSource As Variant) Dim i As Integer Dim j As Integer Dim dblTmpVal(2) For i = UBound(arSource) To LBound(arSource) Step -1 For j = LBound(arSource) + 1 To i '<-- Check for the X coordinates first and if they are equel - '<-- compare the the Y coordinates --> If ( _ (arSource(j - 1, 0) > arSource(j, 0)) _ Or ( _ (arSource(j - 1, 0) = arSource(j, 0)) _ And _ (arSource(j - 1, 1) < arSource(j, 1)) _ ) _ ) Then dblTmpVal(0) = arSource(j - 1, 0) dblTmpVal(1) = arSource(j - 1, 1) dblTmpVal(2) = arSource(j - 1, 2) arSource(j - 1, 0) = arSource(j, 0) arSource(j - 1, 1) = arSource(j, 1) arSource(j - 1, 2) = arSource(j, 2) arSource(j, 0) = dblTmpVal(0) arSource(j, 1) = dblTmpVal(1) arSource(j, 2) = dblTmpVal(2) End If Next j Next i SortArrayByCoords = arSource End Function
HTH.
har!s
