Has anyone come across this message in AutoCAD LT 2007, and do you have a solution for it?
Thanks
Wayne
Thanks
Wayne
Wayne, I'm going to move this from the Autocad (full) 2007 General forum to this one, as I believe it will be better served here, thanks!
Good luck.
Originally Posted by wayne.115304
Melanie Stone
@MistresDorkness
Technical Editornot all those who wander are lost
Looks like a few other people...
Check these threads and replies.
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=4191
http://discussion.autodesk.com/threa...hreadID=390227
http://discussion.autodesk.com/threa...hreadID=316981
If after reading these, you decide that running a "repair" is needed, and you are not sure what this means, take a look at http://cadpanacea.com/node/32
R.K. McSwain | CAD Panacea |
