Results 1 to 10 of 10
Thread: Safe to install previous version w/ current?
    I could stop if I wanted to Haden's Avatar
    2004-05
    St. Louis, Missouri
    292
    Default Safe to install previous version w/ current?
    I currently have Revit Building 8.1 and 9 installed on my PC. Is there any reason why I am not safe installing Revit 8 now as well? Thanks in advance.
    All AUGI, all the time Justin Marchiel's Avatar
    2004-07
    Penticton, B.C., Canada
    954
    Default Re: Safe to install previous version w/ current?
    i too have 8.1 and 9 installed. I also have ADT 06, and07, and viz 06 and 07. I think at this stage of the game they are all fairly stable to all work together.
    Can't say i have much experience with 8, but i have installed a training version on a machine and then 9.0 onto the same machine (forgetting about the and everything seemed to be ok.
    Justin
    2004-05
    St. Louis, Missouri
    292
    Thanks, Justin, for your quick reply. I think I'm ok with multiple versions, but my only real concern is whether it will work to install an earlier version on top of 2 later versions.
    Aussie Revit Moderator Mr Spot's Avatar
    2004-05
    Brisbane
    1,115
    It should still install. Just note your file associations will get reassociated to version 8. Meaning double clicking a file may result in the error stating this file was created in a later version...
    HTH.
    Chris Price
    Co-Founder/BIM Manager/Product Designer
    Xrev Pty Ltd
    Revit Rants BLOG
    2004-05
    St. Louis, Missouri
    292
    Quote Originally Posted by Mr Spot
    It should still install. . . . HTH.
    Thanks. Now my problem is I thought I had copied the install file from our server when I left the office today, but I did not. My offisite backup copies have everything but 8.0, and I can't find anywhere on Autodesk.com to download previous versions.
    Anyone have any ideas where I could get the Revit 8 install file? (I am a current Revit Building 9 subscription holder.)
    2004-05
    Brisbane
    1,115
    I've got a copy of RevitBuilding8.0_20050523_2300.exe if there is someway i can get it to you...?
    Chris Price
    Xrev Pty Ltd
    Revit Rants BLOG
    2003-05
    Northbrook, IL
    879
    My understanding is that you can have different major releases on the same machine but not "point" releases. For instance you could have 4.5, 5.1, 8.0 at the same time but you can't have 4.1 with 4.5 or 8.0 with 8.1, etc.. Proceed with caution.
    All AUGI, all the time Elmo's Avatar
    2005-04
    South Africa
    959
    I have had 8.0, 8.1 and 9.0 installed and I haven't had any problems. Since I don't use 8.0 anymore I decided to delete it from my machine. Haven't tried installing a back version before though and I haven't heard of someone doing so either.
    2004-05
    Silver Spring, MD
    88
    http://revit.autodesk.com/Building/8...load.asp?en-us
    I clicked on the "download 8.1" link and then changed it to 8.0 in the address. I clicked on this new "download 8" link and it started to download the exe file.
    2004-05
    St. Louis, Missouri
    292
    Quote Originally Posted by bclarch
    I have again installed 8 in addition to my 8.1 and 9, and it seems to work fine. In fact, I didn't even have to put in my license or serial number again. I guess all that was still stored in my registry from when I had 8 installed previously. It is good to know that this does work.
    I don't know if I mentioned my reason for needing to do this, but I'm teaching a Revit workshop at a local community college here in St. Louis, and they are not 1 but 2 versions behind there.
  1. Standard fitting from previous version to latest version
    By ashah.200984 in forum AMEP General
    Last Post: 2008-12-18, 04:25 PM
  2. Previous Version Use Benefit
    Last Post: 2008-05-28, 11:35 PM
  3. New version of Previous.lsp
    By madcadder in forum AutoLISP
    Last Post: 2007-11-02, 11:50 PM
  4. Save to previous version
    By Shizzjr in forum AutoCAD General
    Last Post: 2007-10-29, 01:24 PM
  5. Save As <previous version>
    By a-mi in forum Revit Architecture - Wish List
    Last Post: 2004-11-24, 11:01 AM
