Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: HP 1050c Plotter issues
  1. #11
    All AUGI, all the time janunson's Avatar
    2003-07
    Grand Rapids, MI
    650
    Default Re: HP 1050c Plotter issues
    I've opened an SR on this - we've been able to isolate the issue to specific sheets on specific projects, only in 9.0 (i think.. hard to prove.) Let you know if i get anywhere.
    "It is a besetting vice of democracies to substitute public opinion for law." (James Fenimore Cooper)
    ""Interesting. No, wait...that other thing. Tedious."
    --Bender on Futurama
  2. #12
    2003-07
    Grand Rapids, MI
    650
    Quote Originally Posted by Martin P
    Already tried the in computer option here, didnt make any difference to me?....... when I try to print from Revit 9.0 to the 1050c it actually knocks out all of the other as well printers for about 5 minutes.
    postcript or non postscript drivers though, not sure whats on it now will check it out.
    I've found that the print spooler service is crashing on the printer. You can go into the services for the server, set restart parameters for the print spooler service and avoid some of the pain - still have drawings dropping out of the que, and a lot slower running, due to the service crash/restarts, but it helps some.
  3. #13
    All AUGI, all the time Alex Page's Avatar
    2003-07
    Wellington, New Zealand
    793
    Anyone found a fix for this?
    Alex Page
    RevitWorks Ltd
    Check out the Door Factory, a door maker add-in for Revit
  4. #14
    I could stop if I wanted to neb1998's Avatar
    2004-06
    Chicago
    367
    you may want to alter the setting for optimize for pictures or for drawings/lines....i have found with pdfs and drawings that each setting can make a major difference in plot time
    Ben Kane
  5. #15
    2003-07
    793
    Quote Originally Posted by neb1998
    Thanks for the suggestion - but no go - still crashes my print spooler
    Alex Page
    RevitWorks Ltd
  6. #16
    2003-12
    87
    We've discovered that Revit 9 won't print to either the HPGL or PS queues, asn are now converting to PDF's before plotting. Quite a nuisance.
    Luckily, we only use this for colour - Oce works fine for working drawings.
    C (also in NZ)
  7. #17
    AUGI Addict bowlingbrad's Avatar
    2003-11
    Chicago
    1,224
    Has the Factory been any help?
    Brad Novak
    Director of Information Technology
    Gp GOETTSCH PARTNERS
    Chicago, IL
  8. #18
    2013-02
    Farnborough Hants
    setting the pc to control the spooling in plotter configuration is a good option but it slows down everything until the plot is completed. Tryadding more RAM (pc133 64MB) to the plotter. I am using Revit 13 out of BIM box and can see your problem.
    Try converting to NAVIS as the file is much smaller and then send to plot from Navis Works. Failing that convert to dwg file and then use DWG to plot option from plot menu and there you are. PDF take longer to spool but make sure you use AutoCAD pdf as it maintains your line thicknesses and not make them bleed like Adobe pdf.
  1. Drawings taking to long to send to 1050C plus plotter
    By kimlance in forum AutoCAD General
    Last Post: 2009-03-20, 10:42 AM
  2. HP 1050c Issues
    By pthutcherson in forum AutoCAD General
    Last Post: 2009-03-11, 05:50 PM
  3. Window Vista hp 1050c Plotter driver needed
    By Firmso in forum AutoCAD Plotting
    Last Post: 2007-10-02, 06:41 PM
  4. ABS 2007.1 - Xrefs causing plotter issues
    By ordengate in forum AMEP General
    Last Post: 2007-01-02, 05:26 PM
  5. Plotting issues with HP designjet 500 42" plotter
    By akall in forum AutoCAD Plotting
    Last Post: 2005-03-08, 02:55 AM
