Results 1 to 10 of 18
Thread: HP 1050c Plotter issues
    Member clydej's Avatar
    2005-04
    South Africa
    26
    Default HP 1050c Plotter issues
    Hopefully i'm posting in the correct section.
    Anyways, I have an HP 1050c plus. The plotter works fine out of Revit 8.1, but creates the folowing error out of Revit 9.0:
    Spooler Subsystem App has generated an error.
    has anyone experienced anything similar and how did you fix it?
    2003-04
    Scotland
    1,577
    Default Re: HP 1050c Plotter issues
    We have the same printer and the same problem with R9.0 only. We have to print a PDF first then print that - this has been our only solution. Fortunately we dont use that plotter so often as its only for colour prints over A3 size, so I havent complained yet. But we are getting the exact same issue....
    2005-04
    South Africa
    26
    Thanks for the reply. Pity there isn't a fix for this.
    100 Club gibson.tim91884's Avatar
    2005-08
    Edmonton, Canada
    118
    Check the driver? We have the 1050C, and HP has postscript and non-postscript drivers. I've found that the PS drivers don't work very well with Revit. I haven't noticed your problem here, though, so this is just a shot in the dark.
    AUGI Addict bowlingbrad's Avatar
    2003-11
    Chicago
    1,233
    Try setting the driver to process "in computer" and not "in printer". Slower, but usually fixes the issues.
    All AUGI, all the time janunson's Avatar
    2003-07
    Grand Rapids, MI
    650
    We've had the same issue... In computer sometimes fixes the problem.
    2005-04
    South Africa
    26
    Thanks for the response guys, I will try the in computer option. I have had feedback from one of the resellers in Port Elizabeth. He recommended that I change the Raster quality to low.
    Will advise on further developments.
    2003-04
    Scotland
    1,577
    Already tried the in computer option here, didnt make any difference to me?....... when I try to print from Revit 9.0 to the 1050c it actually knocks out all of the other as well printers for about 5 minutes.
    postcript or non postscript drivers though, not sure whats on it now will check it out.
    2005-04
    South Africa
    26
    Setting the Raster quality allows you to plot! Simple solution to a big problem.
    Thanks guys.
    All AUGI, all the time Alex Page's Avatar
    2004-03
    Wellington, New Zealand
    822
    Quote Originally Posted by clydej
    Thanks guys.
    Unfortunately I need better quality then that
    Note there is anouther thread on this problem:
    http://forums.augi.com/showthread.ph...8&page=1&pp=10
  1. Drawings taking to long to send to 1050C plus plotter
    By kimlance in forum AutoCAD General
    Last Post: 2009-03-20, 10:42 AM
  2. HP 1050c Issues
    By pthutcherson in forum AutoCAD General
    Last Post: 2009-03-11, 05:50 PM
  3. Window Vista hp 1050c Plotter driver needed
    By Firmso in forum AutoCAD Plotting
    Last Post: 2007-10-02, 06:41 PM
  4. ABS 2007.1 - Xrefs causing plotter issues
    By ordengate in forum AMEP General
    Last Post: 2007-01-02, 06:26 PM
  5. Plotting issues with HP designjet 500 42" plotter
    By akall in forum AutoCAD Plotting
    Last Post: 2005-03-08, 03:55 AM
