Thread: Structural Floor Level vs Finished Floor Level
    2005-12
    3
    Default Structural Floor Level vs Finished Floor Level
    Is the Level in Revit defined as the Finished Floor Level? I would like to define it as Structural Floor Level and when different finishes apply onto it e.g. 50mm tile and screeding or 25mm carpet and underlay etc., the levels remains unchanged.
    At the moment, when new floor type are defined, the structural floor slab shift down but keep the finished floor unchanged.
    Anyone can help?
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,439
    Default Re: Structural Floor Level vs Finished Floor Level
    currently you must select your floor and move it up the thickness of your finish. This has always been a pet peeve of mine, but I don't think I've ever placed a support or wishlist. I find the same with ceilings too. I want to be able to say the stud framing is 8.0aff not the gyp.
    Scott D. Brown, AIA
    Project Coordinator | Director of Building Information Modeling
    HHCP.com
    AUGI Addict Andre Baros's Avatar
    2003-12
    Point of no return
    1,604
    We use the same convension, Level = Top of Structure, but sometimes add a seperate level for top of finish floor because doors by default insert at the current level and it can get tedious to move them all up by the thickness of your architectural floor. This is an issue for us because most of our architectural toppings are 2-3 inches thick.
    All AUGI, all the time Elrond's Avatar
    2004-03
    Hereford, UK
    820
    If it is critical you could always place 2 floors - a structural slab and a finish material. If you set the structural slab to level and then lock the finish material floor to the structural slab it should work.
    Elrond Burrell, Architect
    [Connect with me on LinkedIn or Twitter]
    "The best time to plant a tree was 20 years ago. The second best time is now."
    - Chinese Proverb
    2001-07
    Phoenix, AZ
    959
    To push this one step further... you might try using a Floor and a Roof instead of two Floors.
    I know, it sounds weird but if you consider that Floors grow in thickness from the top-down and Roofs grow from the bottom-up then it starts to make some sense.
    Our floor finishes are typically not thick enough to warrant this approach but I have used it successfully for flat roofs.
  1. Floor Level tag
    By nnamdiakubuiro in forum Revit Architecture - Families
    Last Post: 2011-05-23, 01:56 PM
  2. Sloping floor is not on set level
    Last Post: 2009-07-26, 03:13 PM
  3. Floor Level Annotation
    By chriscooper in forum Revit Architecture - General
    Last Post: 2005-09-07, 10:07 AM
  4. Can a floor plan become a level?
    By david.kingham in forum Revit Architecture - General
    Last Post: 2005-07-07, 09:27 PM
  5. Columns insert at a 0 level and not my floor level
    By wingman in forum Revit Architecture - General
    Last Post: 2005-04-25, 07:25 PM
