Results 1 to 9 of 9
Thread: Access a Vport inside a Vport
    I could stop if I wanted to johan d's Avatar
    2006-01
    Belgium
    287
    Question Access a Vport inside a Vport
    I created a viewport inside another viewport.
    if i want to access this smaller vport in paperspace i double click in it, but it makes the bigger vport accessible...? any idea how i can get acces (modelspace) to this smaller vport?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,104
    Default Re: Access a Vport inside a Vport
    From this post, I would suggest using CTRL-R to cycle through your viewports.
    I could stop if I wanted to lmitsou's Avatar
    2003-01
    UK
    219
    Although Ctrl + R is the best option in my opinion, you also have another one. I am talking about the maximize viewport button which is located in the middle of the Tray (see attachment).
    2006-01
    Belgium
    287
    Ctrl+R is what i was looking for - thanks
    2002-01
    jUSt Here (a lot)
    9,104
    Quote Originally Posted by lmitsou
    If you are in the wrong viewport, how will maximizing it get you to the right one?
    2003-01
    UK
    219
    Quote Originally Posted by Opie
    By using the left and right arrow next to the button (please see attached).
    2002-01
    jUSt Here (a lot)
    9,104
    Thank you for the additional detail.
    2003-01
    UK
    219
    You are welcome. It was actually my mistake for not adding this "detail" in my first post.
    2004-10
    22
    Another way to do it (or select an entity that is under one or more others) is to hold down the shift key while left clicking the mouse on or close to the object.
    When the item that you want is highlighted, right click to select it.
    Noun-verb selection should be on if you want to edit it.
  1. 2013: Vport Layer
    By Darren Allen in forum AutoCAD Civil 3D - General
    Last Post: 2014-11-17, 07:17 PM
  2. Vport en Civil 3d 2010
    By mbravo333 in forum AutoCAD Civil 3D - General
    Last Post: 2010-01-09, 03:34 PM
  3. Lost in MSpace from Vport
    By v12v12 in forum AutoCAD LT - General
    Last Post: 2008-05-06, 03:43 PM
  4. Set vport scale via lisp
    By cadpoobah in forum AutoLISP
    Last Post: 2006-05-18, 12:04 AM
  5. Lock Vport Lisp
    By BCrouse in forum AutoLISP
    Last Post: 2005-10-19, 09:31 AM
