ok, a co-worker has 2 sheets in his set that is incorrectly listing the scale of the viewports he's placing. between these and the sheets that work, the fields have the same settings. what i have them set to normally is 'use scale name'. what happens is the view gets placed from the source tab, r.click to select scale, and in this case, either 3/4"=1'-0", or 1 1/2"=1'-0". what we get in the view title is 1:16, or 1:8. it also stayed that way when trying to change the v.p. scale in the properties dialog box. I had to change how the field interpreted the viewport scale so he wouldn't have to re-build the sheets.
any ideas?
