Results 1 to 7 of 7
Thread: 3 Point Rectangle
    ACAD Wish List Administration
    2005-06
    1,920
    Default 3 Point Rectangle
    Summary: The option to draw a rectangle using 3 points
    Description: Add a 3-point option to the rectangle command so you can draw a perfect rectangle at another angle besides orthographic.
    How Used: Everyone has to draw rectangles, and they are not always oriented orthographically. With the popularity of scanners and the ability to "trace" pictures in AutoCAD, tracing rectangular objects would be a snap even when they are rotated. Since CIRCLE has a 3 point option, you can select 3 places along the edge of a circle on your image which is easier than trying to guess where the center is. If RECTANGLE had a 3-point option, you could select 2 of the corners and drag the rectangle out dynamically to the third point.
    Feature Affinity: Drawing Tools 2D
    Submitted By: Robert Privette on June 23, 2006
    2005-09
    Canada
    214
    Default Re: 3 Point Rectangle
    Robert,..
    If you know lisp programming...
    this seem easy to make with lisp...
    please explain the process's you need to enter...
    and I'll make something 4 u.
    Active Member Cadtharsis's Avatar
    2006-02
    Pi World. It's not what I was thinking. :(
    90
    Honestly andrea, do not respond to a request that way. If we all knew how to program lisp, we wouldn't need a wish list, now would we?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,104
    The RECTANGLE command does allow you to set the rotation during the command. It's not three consecutive points but it is three points with one option entered in the middle somewhere.
    HTH
    Earth
    9,805
    Quote Originally Posted by Opie
    True. That was added back in r2006
    R.K. McSwain | CAD Panacea |
    2011-08
    4,581
    Exclamation Re: 3 Point Rectangle
    This wish has been reported as granted and already in the software.
    2011-08
    4,581
    The wish has already been granted. This thread is closed to further posts.
  1. Center Point Sketch Rectangle
    Last Post: 2015-10-12, 03:53 PM
  2. Center Point Rectangle
    Last Post: 2015-10-12, 03:29 PM
  3. Create rectangle then move at center point
    By CISCO in forum AutoLISP
    Last Post: 2010-11-14, 04:33 PM
  4. Replies: 10
    Last Post: 2007-03-23, 01:50 AM
  5. centre point of a rectangle/box
    By jesse.86737 in forum AutoCAD Wish List
    Last Post: 2005-05-13, 08:25 PM
