Results 1 to 10 of 12
Thread: Xref file is not loading for some reason...
    2003-02
    60
    Default Xref file is not loading for some reason...
    Ihave an Architectural floor plan drawn to attach to future sheets named A0-BASEPLAN.
    Working on another new sheet I XREF the ABOVE drawing & place it where needed. On my current working drawing at the 0,0 coordinate for the referenced A0-BASEPLAN the following text appears:
    Xref A0-BASEPLAN
    How do I remove this? Hope the explanation is not too confusing.
    Thanks
    Bjack
    2001-10
    Arizona
    2,337
    Default Re: Xref file is not loading for some reason...
    Quote Originally Posted by bjack56
    Xref A0-BASEPLAN
    Thanks
    Bjack
    Use the XREF manager to point this file to the CORRECT location of the
    MISSING xref file which is why you see the refference to the missing xref,
    i.e. the text that spells out the missing file name.
    Or use the XREF command to browse to the new path of the missing XREF
    and ensure you check the box that reads SAVE PATH.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    2003-02
    60
    I have detached, attached & save path....still TEXT there. When I pick the text the XREF part of the drawing highlights.
    Any more suggestions???
    All AUGI, all the time bbapties's Avatar
    2003-12
    Palm Harbor, FL
    537
    It sounds like you have an xref that was accidentally erased and not detached.....
    try detaching it, erase the text, do a purge all, then reinsert your x-ref......
    hope this helps
    bcb
    Administrator RobertB's Avatar
    2001-08
    Dallas TX USA
    5,825
    That XRef, A0-Baseplan, is not resolving. It sounds like there is an XRef of that name in the drawing that you are XRefing into the current drawing. Switch the XRef Manager to tree view. Do you see indication of a missing XRef there? Post a png/jpg of that dialog if you don't understand what you see there.
    2003-02
    60
    Detached, deleted, erased, purged, closed, open.........
    No XREF listed in Base drawing or working drawing. Closed the ACAD & attached XREF again & same text as in my original post shows up.
    More help please??
    2001-08
    Dallas TX USA
    5,825
    Zip up your drawings and email them to me.
    2001-10
    Arizona
    2,337
    Robert you took the words right off my keyboard
    Zip up those files and send them to me.....
    Be your Best,
    Michael Farrell
    2001-08
    Dallas TX USA
    5,825
    Must be just slightly faster on the keyboard!
    2001-10
    Arizona
    2,337
    Actually,
    I didn't notice the time of the post.
    I had just returned from meeting
    some folks and picking up some data
    for and earthwork project for over the week-end.
    Just my way of stay in-tune with the processes
    and methods others are using, to improve the
    classes I teach.
    Be your Best,
    Michael Farrell
  1. multiple Xref Loading
    By Doodlemusmaximus in forum AutoCAD General
    Last Post: 2011-05-24, 02:26 PM
  2. Xref's not re-loading.???
    By rhayes.99001 in forum ACA General
    Last Post: 2007-07-03, 08:55 PM
  3. Xref's not re-loading
    Last Post: 2007-05-04, 08:09 PM
  4. DWG file size appears big for no reason - AutoCAD LT
    By bmiller.73395 in forum AutoCAD LT - General
    Last Post: 2006-10-19, 05:34 AM
  5. Drawing file size is big for no reason
    By gmatheson.88942 in forum AutoCAD General
    Last Post: 2006-02-13, 06:16 PM
