Thread: Walls and Columns
    All AUGI, all the time dpasa's Avatar
    2004-08
    Greece
    636
    Thumbs down Walls and Columns
    See the attached image for details.
    When a column is placed, it doesn't cut the wall. So now when I make a schedule for the walls, I get wrong results, since in reality the wall doesn't go through the column.
    Join geometry doesn't work. What must I do?
    2003-04
    236
    Default Re: Walls and Columns
    I just tried to duplicate what you are doing. I am assuming you are using a concrete "structural" column and not an architectural column. When I place the structual column it does not cut the wall geometry (as expected) and then I use join geometry and all is well.
    Try again.
    All AUGI, all the time ford347's Avatar
    2005-01
    Oroville, CA
    867
    You can't join structural geometry.
    2003-04
    236
    Here is a generic wall with two structural concrete columns, one joined and one unjoined
    2004-08
    Greece
    636
    Boy, that was stupid of me!
    Thank you all
  1. Replies: 5
    Last Post: 2012-07-12, 09:25 PM
  2. Walls intersecting columns?
    By marcu_p_mihai in forum Revit - Platform
    Last Post: 2009-09-11, 03:12 PM
  3. R2009 - Columns and Walls
    By angus.110169 in forum Revit Architecture - General
    Last Post: 2008-10-03, 04:05 PM
  4. Loadbearing walls and columns - again
    By JH75 in forum Revit Structure - General
    Last Post: 2008-08-20, 05:28 AM
