Thread: Purge failed - Continuous Loop with 'acdb OpenObject failed' displayed
    2006-03
    Default purge failed
    an attempt to purge occasionally results in a continuous loop on the command line "acdb OpenObject failed".
    once this happens, the loop can only be stopped by shutting down autocad.
    of course, i have had to adopt the custom to "save" before ever purging, to avoid loosing any recent changes.
    0,0,0 The Origin
    8,570
    Default Re: Purge failed - Continuous Loop with 'acdb OpenObject failed' displayed
    I think you should try "audit" and/or "recover" on files that cause this behaviour.
    I've never seen this but it sounds as if the file(s) is corrupt.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Please note I have *moved* this thread from the New Forum Users Forum to this one as I believe it would be better served here.
    Below snippet is from the small print on the Forum General page -
    <snip>
    New to the Forums? This is the place to experiment with the posting editor and learn how to interact with our forums. Please experiment here with forum features and commands.
    </snip>
    Richard
    Forum Moderator
  1. Run Failed
    By abechard in forum Green Building Studio - General
    Last Post: 2009-12-28, 09:05 PM
  2. Seek Failed
    By sthedens in forum Revit Structure - General
    Last Post: 2008-03-04, 09:01 PM
  3. seek failed on ---.rvt
    By peakprecisiondesign in forum Revit Architecture - General
    Last Post: 2007-10-08, 07:17 PM
  4. VBA install failed
    By jkhouseart in forum VBA/COM Interop
    Last Post: 2005-08-17, 03:54 PM
