Thread: Parametric MvPart creation fatal error in ABS2006
    All AUGI, all the time Avatart's Avatar
    2004-06
    here, watcha gonna do?
    926
    Default Parametric MvPart creation fatal error
    I have a problem with my ABS2006, every time I try to create a parametric MvPart, I get to name it, add a descrption, then when I click "Next", the drawing starts to regenerate and I get a fatal error.
    Has anyone else experienced this? Does anyone know of a way to stop it happening?
    FYI: PC is 3GHz, 1Gb RAM, software graphics acceleration, fully service packed - problem has been consistent across all service packs and whatever drawing is open.
    PS, Why is there no smiley icon in floods of tears? This is an AutoDesk forum after all...
    2002-09
    Madison, WI
    4,439
    Default Re: Parametric MvPart creation fatal error in ABS2006
    Quote Originally Posted by carl_hd_collins
    Nope, it's an Augi Forum. "User" being the key word.
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
  1. 2012: Revit mep: Export to dwg fatal error. Sync fatal error as well
    By Scottybill in forum Revit MEP - General
    Last Post: 2012-11-30, 08:47 PM
  2. Parametric MvPart: Return Grille
    By ameador in forum Parts Builder
    Last Post: 2007-11-15, 12:38 AM
  3. Parametric array creation error
    By E-Key in forum Revit Architecture - Families
    Last Post: 2006-05-26, 07:42 PM
  4. Replies: 2
    Last Post: 2005-11-04, 12:46 AM
  5. Fatal Error on creation of REM Region.
    By campbell.58097 in forum Raster Design - General
    Last Post: 2005-07-11, 05:54 PM
