Thread: Converting a block into a solid
    Default Converting a block into a solid
    Hey all im kinda new at this 3D stuff, is there anyway to convert a 3D block into a solid. I have a 3d drawing that i exported from Sketchup and i want to convert it into a solid and get the advantages that autocad has to offer. please help.
    Pedro Gastelum Jr.
    CAD Tech
    0,0,0 The Origin
    8,570
    Default Re: Converting a block into a solid
    If it's a Block in acad terms, Explode it. You should still have the Sketch-up object. Whether or not that can be made into a solid, I've no idea - but I'd like to know.
    2006-08
    could you post it?
    2002-09
    Madison, WI
    5,688
    Quote Originally Posted by jaberwok
    wouldn't the burst command work better. I tend to find that the explode command tends to return faces or meshes. Burst tends to be a little more gental.
    0,0,0 The Origin
    8,570
    I doubt that it is an acad-compatible block.
    #down by the riverside, down by the riverside#
  1. Converting a Loft to a solid
    By cchallis in forum AutoCAD 3D (2007 and above)
    Last Post: 2009-09-07, 11:05 AM
  2. Converting a 2D drawing into a 3D solid
    By iluvepanther in forum Inventor - General
    Last Post: 2007-09-06, 07:13 PM
  3. converting a polyface mesh to a solid
    By jgray in forum ACA General
    Last Post: 2005-12-31, 05:22 PM
