Results 1 to 8 of 8
Thread: Metal Cornice
    All AUGI, all the time BomberAIA's Avatar
    2003-05
    Boca Raton, FL
    652
    0 Did you find this post helpful? Yes
    Question Metal Cornice
    I am trying to create a metal parapet cap in profiles. When I do a sweep, I get an error. Has anyone run into this problem?
    2003-05
    Boca Raton, FL
    652
    Question Re: Metal Cornice
    OK, I found my mistake. A profile must have closed lines. Now I can not get the wall sweep to follow a curved parapet. Any ideas?
    2003-05
    5,153
    Default Re: Metal Cornice
    Try using " Pick Path" in a 3D view.
    Bruce Gow.
    Karel*CAD. Application Specialist..
    Architect.
    Revitalize. Blog
    2003-05
    Boca Raton, FL
    652
    Cool Re: Metal Cornice
    I've tried: modelling, host sweep, wall sweep, but it won't work on a curved or sloped parapet. Are you saying I must create a in place wall sweep?
    2003-05
    5,153
    Host sweep -wall sweep should work. Place the default profile first then swap it out.
    If you having problems, can you post an image or mini file ?
    Bruce Gow.
    Architect.
    Revitalize. Blog
    2003-05
    Boca Raton, FL
    652
    Post Re: Metal Cornice
    What do you mean;swap it out? I will post an image when I get to work today. Thanks
    AUGI Addict PeterJ's Avatar
    2003-04
    London, UK
    1,948
    Quote Originally Posted by BomberAIA
    I think the logic runs that these elements are essentially created in-place, as I imagine you have edited the profile or used a void cut, so the automatic tools won't work and yes, you'll need to do some smarter modelling.
    It should only be a case of defining a profile family and loading it (so that it can be reused) then selecting the path by picking in a 3D view.
    Pete
    2003-05
    5,153
    Substituting another profile for the default profile used by the Host Sweep tool.
    Bruce Gow.
    Architect.
    Revitalize. Blog
  1. Cornice Detail
    By smooth shoes in forum AutoCAD General
    Last Post: 2010-04-01, 01:52 AM
  2. How do I represent a Metal Panel Wall or Metal Roofing?
    By rgecy in forum Revit Architecture - General
    Last Post: 2009-05-09, 05:35 PM
  3. corrugated metal roof and metal siding textures
    By hdjohnson in forum Revit - Rendering
    Last Post: 2003-12-21, 06:48 PM
  4. Cornice Problem
    By BomberAIA in forum Revit Architecture - General
    Last Post: 2003-06-07, 04:24 PM
