Results 1 to 10 of 11
Thread: Autosave time resets itself
    I could stop if I wanted to Merlin's Avatar
    2004-05
    Brisbane, Australia
    405
    Question Autosave time resets itself
    Hi, gang,
    I posted this question in the AutoCAD 2007 forum the other day, I've since found out it the scenario was occurring in some of our 2006 versions as well.....this is the problem:-
    With a few of our liscences, we're having trouble with changing our Auto save time. Whether we go to OPTIONS and change the time there, or if we use the "SAVETIME" sysvar, the result is the same....it always resets the time back to 45 minutes, completely disregarding whatever we changed it to.
    I know it's not a major thing, just an annoyance. Any comments?
    John Mc
    Earth
    9,805
    Default Re: Autosave time resets itself
    Once again, let me make sure I understand.
    If you type in SAVETIME, set it to 5, then press enter it is immediately set back to 45?
    So your command line looks like this?
    Command:
    SAVETIME
    Enter new value for SAVETIME <45>: 5
    Command:
    SAVETIME
    Are you in a network environment?
    Is it possible that someone has installed a routine to keep SAVETIME set at 45?
    Do other variables "reset themselves"?
    R.K. McSwain | CAD Panacea |
    2004-05
    Brisbane, Australia
    405
    I think you're right ...it may be a network problem...I'll check that out......thanks
    AUGI Director scott.wilcox's Avatar
    2015-11
    Edmonton, Alberta
    990
    Perhaps a LISP routine also is resetting the SAVETIME every time it is run.
    2004-05
    Brisbane, Australia
    405
    UPDATE:....
    We're still looking into it and it certainly seems to be a network thing....at present we're looking at a "work-around" and making a lisp routine to set things at the start-up....when we find the location of the offending coding, we'll be make the appropriate changes then.....thanks all for your advice
    John Mc
    All AUGI, all the time thomas.stright's Avatar
    2015-12
    Texas
    564
    We have eliminated the use of auto-save altogether. Of course proper training is a must.
    100 Club The VLG's Avatar
    2005-04
    on the up....
    137
    Quote Originally Posted by thomas.stright
    I like to use AutoSave, but my pc is less happy & I occasionally find that it has decided to turn itself off completely. Now I'm must say that I very rarely need to go hunting for one, I think I just like the safety net being there.
    2002-09
    Madison, WI
    5,688
    It sounds to me like some one hard coded it in the front end set up. We had the issue as well, but the our Cad Manager changed it back to allow users to reset it.
    13,656
    Hi
    The following thread may help...
    AutoSave Resetting to 0
    Have a good one, Mike
    2015-12
    Texas
    564
    Quote Originally Posted by VLG
    The reason we have it off is due to files being corrupted during the autosave.
  1. AMPOWEREDIT resets ATTDIA
    By larry.fogolin in forum AutoCAD Mechanical - General
    Last Post: 2010-05-12, 08:10 PM
  2. DIMSCALE resets to 0
    By tgross.197084 in forum AutoCAD General
    Last Post: 2009-09-25, 06:25 PM
  3. Autosave should work all the time
    By kevin.bell.72378 in forum ACA Wish List
    Last Post: 2009-05-27, 03:49 PM
  4. Dimscale resets itself
    By frogge in forum AutoCAD General
    Last Post: 2005-03-31, 10:13 PM
