Thread: Convert .CDR files to .DWG or .DXF
    I could stop if I wanted to macwizzy06's Avatar
    2005-09
    Nigeria, Africa
    245
    Question Convert .CDR files to .DWG or .DXF
    I'm having issues with converting *.cdr* drawing (architectural layouts & elevations) files to .dwg or .dxf.
    I'm not sure if these drawings were originally made with AutoCAD but when I attempted a Save-as using the .dwg, I got one AutoCAD picture and nine .jpg files. By AutoCAD picture, I mean a picture pasted in AutoCAD and edited with Paint. On the other hand, when I saved as .dxf, nothing was saved.
    Does this mean that I cannot successfully convert these to drawings to AutoCAD? That would mean that I won't be able to modify it cos I didn't even bother trying in CorelDraw, as I hate doing layout drawings with that software... or any other for that matter. Well, except... ofcourse now, Revit.
    Any help? Anyone?
    Wisdom S. M.
    AutoCAD 2006
    Revit Newbie
    "If you think you're too small to make a difference, try going to bed with a mosquito"
    "Motherhood is hard, saying thanks is easy. Have you said 'Thank you' to Mama?"
    2002-02
    St. Louis, MO
    4,695
    Default Re: Convert .CDR files to .DWG or .DXF
    Quote Originally Posted by macwizzy06
    Any help? Anyone?
    CDR is CorelDraw's file format. These can be translated to DWG or DXF using CorelDraw.
    Don't drink the Kool-Aid...
    Aaron Rumple, AIA
    All AUGI, all the time scott.wilcox's Avatar
    2015-11
    Edmonton, Alberta
    990
    When exporting CDR files to DWG or DXF, Corel will only convert the vector bits to DWG or DXF, the raster bits are excluded.
    Why draw straws? Just draw one straw and array it.
    Scott Wilcox - Edmonton, Alberta
    2005-09
    Nigeria, Africa
    245
    Quote Originally Posted by aaronrumple
    Exactly! And this seems like the origin of the problem...
    Wisdom S. M.
    AutoCAD 2006
    Revit Newbie
    2005-09
    Nigeria, Africa
    245
    Quote Originally Posted by scott.wilcox
    The vector bits I got seem to be 'uneditable' (pardon my grammar) in AutoCAD. Double-clicking opens it up in Paint for editing.
    It's a 10-layout .cdr file, after exporting (using File > Save as) to .dwg only 1 layout (the current layout) converted, others were converted to .jpg. I believe that if these other layouts are made current and saved, they'd each convert to .dwg.
    My question stems from the fact that all these converted files cannot be edited in AutoCAD, and I really need to _ork on them. So I was hoping that someone would have a way to workaround this... and I still haven't given up on that hope
    Wisdom S. M.
    AutoCAD 2006
    Revit Newbie
  1. Batch convert DXF files to DWG files
    By Doodlemusmaximus in forum AutoCAD Customization
    Last Post: 2015-04-02, 05:19 PM
  2. Replies: 0
    Last Post: 2007-05-22, 08:14 PM
  3. AutoCAD LT 2005 convert DWG files into JPG files?
    By dougm.79335 in forum AutoCAD LT - General
    Last Post: 2007-02-09, 01:28 PM
  4. Can you convert/export Revit files into pdf or plot files?
    By petercronin in forum Revit Architecture - General
    Last Post: 2005-12-09, 01:47 AM
