Results 1 to 6 of 6
Thread: Plot and Publish log files do not show number of copies
    I could stop if I wanted to dfarris75's Avatar
    2004-12
    where ever i'm at
    252
    Default Plot and Publish log files do not show number of copies
    The plot and publish log file doesn't seem to show the number of copies printed when making multiple prints from a sheet set. Am I missing something???
    Is there a way to get it to show the number of copies? I'm looking for a log to use for billing purposes and it needs to show this information...
    I could stop if I wanted to Doodlemusmaximus's Avatar
    2005-04
    RAT HALL
    297
    Default Re: Plot and Publish log files do not show number of copies
    What are your settings for them at the moment. And where are you storeing your log file?
    CAD RAT AKA Mr dribble, AKA Grumpy Old Man.
    100 Club Olaf.Banckaert's Avatar
    2006-02
    Belgium
    133
    Another possibility (I now it works for HP plotters) you can do is to go to the plotter by his IP and yhen you also can take the liste of paper usage, ink usage, ... and this for each plot.
    2004-12
    where ever i'm at
    252
    Quote Originally Posted by Beldin
    What settings?
    I just changed my log file location yesterday from my local default folder to a folder on our network.
    2004-12
    where ever i'm at
    252
    Quote Originally Posted by Olaf.Banckaert
    We do have this for our new XEROX printer, but according to our book keeper it isn't keeping an accurate record, so since she is using it for billing I looked into using the AutoCAD plot log file instead and that's when I noticed it did not show the number of copies of the sheet set I had just published. It just listed one set rather than 18 sets (of 10 sheets).
    2006-02
    Belgium
    133
    Ok, I don't know the xerox machines, but the HP here does the trick. In the attached file you can see in what for detail.
    And with the command VIEWPLOTDETAILS, you can see the number of the pages. This is for 2006, don't now if it works for older versions...
  1. plot files w/ publish and win7
    By tomcarver in forum AutoCAD Plotting
    Last Post: 2012-05-10, 05:44 PM
  2. Plot and Publish log files do not show number of copies
    By sacha.monnom in forum AutoCAD General
    Last Post: 2010-01-20, 04:15 PM
  3. PUBLISH MULTIPLE COPIES
    By mike.schemm in forum AutoCAD Plotting
    Last Post: 2008-07-22, 03:57 AM
  4. Plot 2 No Copies. 1st Plot is ok! 2nd Plot moves on the paper.
    By gianluca.giusti in forum AutoCAD Plotting
    Last Post: 2006-05-18, 11:02 AM
  5. Plot files from the publish utility
    By tim.101799 in forum AutoCAD Plotting
    Last Post: 2005-12-21, 06:56 PM
