Results 1 to 6 of 6
Thread: Trim, Extend, Fillet, and Grip-Stretch commands - Do I really want to do this?
    I could stop if I wanted to cadpoobah's Avatar
    2003-12
    Central Ohio
    417
    Default Trim, Extend, Fillet, and Grip-Stretch commands - Do I really want to do this?
    This started out as a question, but the more I played with it, the more I began to find/understand. So, I'll just explain what was happening and what I found, fwiw.
    Scenario: One of our drafters has a drawing that informs me "1704 selected. Do you really want to do this?". This is happening on the Trim, Extend, Fillet, and Grip-Stretch commands. I've seen this prompt with Hatch when using the "pick points" to find a boundary, but never on these commands before.
    What's also interesting is that drawing has only 234 entites (when I try an "ERASE All"). One of the objects is an attached raster image. When I detach it, (resulting in 233 entities), the warning still says "1704 selected."
    With the Hatch, you can eliminate this warning by picking objects or limiting what AutoCAD has to "think about" (frz layers, zoom in,etc.). Zooming did nothing, but freezing layers helped.
    After snooping around in the drawing, I found some blocks. If I erased them, and tried fillet/stretch/trim/extend, there was no warning. Also, if I exploded the blocks, it resulted in 1817 entities in the drawing! Go figure!
    Oh, well. At least I was able to fillet the lines.
    0,0,0 The Origin
    8,026
    Default Re: Trim, Extend, Fillet, and Grip-Stretch commands - Do I really want to do this?
    Quote Originally Posted by cadpoobah
    ...Oh, well. At least I was able to fillet the lines.
    A result, then.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    Houston
    7,519
    I think he is modifying something that was used as an associative hatch boundary.
    See: http://support.autodesk.com/getdoc.asp?ID=TS56238
    2004-06
    198
    I used to run into this with Acad 2002 and ADT 3.3. It would happen if there was a complex hatch that was associative or if hatches were associated with x-refs. By changing the hatches to be nonassociative the problem would go away.
    2006-01
    Land of chocolate
    228
    Question Re: Trim, Extend, Fillet, and Grip-Stretch commands - Do I really want to do this?
    is there "empty text" in the drawing??
    100 Club The VLG's Avatar
    2005-04
    on the up....
    137
    I've come across this recently my self with hatching (& I made the mistake of saying yes once, there were tens of thousands involved), but I found that just unloading the x-refs did the trick for me.
    The thing is thought that it wasn't happening all the time.
    verisimilitude is a life choice...probably...
    Cheese...don't believe the hype.
  1. Replies: 0
    Last Post: 2011-06-27, 02:27 AM
  2. stretch/extend arc?
    By randyspear in forum Dynamic Blocks - Technical
    Last Post: 2009-07-20, 06:10 PM
  3. Stretch by grip, grip becomes longer than the actual block
    By cadconcepts in forum Dynamic Blocks - Technical
    Last Post: 2007-03-21, 08:23 PM
