Results 1 to 10 of 13
Thread: Crash - !dbobji.cpp@6266:eNotOpenforWrite
    The Silent Type CADMama's Avatar
    2016-01
    Where reference planes have Defines Origin checked
    1,040
    Default Crash - !dbobji.cpp@6266:eNotOpenforWrite
    OK - so this drawing crashes in 2006 if you insert a block from inside the drawing (or from outside the drawing) then explode the block and Move it. I cannot get it to reproduce the error in 2007 but I can in 2006. The blocks I have used are CUTBLK* within the drawing.
    Any ideas?
    0,0,0 The Origin
    8,570
    Default Re: Crash - !dbobji.cpp@6266:eNotOpenforWrite
    FWIW, with cutblk1, moving the wide polyline and any other object that is part of the block causes the crash. Moving the pline by itself does not cause the crash nor does moving any combination of parts that does not include the pline.
    AUDIT completes but makes no difference.
    2016-01
    1,040
    Does this mean it is stuck in crash mode?
    0,0,0 The Origin
    8,570
    Hi CADMama.
    I don't know, just throwing in some info for others who might be able to figure it out.
    The same question appears in a couple of other groups but seems to be related to ADT - and I found no useful answer.
    Hmm. How about redefining the blocks?
    2016-01
    1,040
    Quote Originally Posted by jaberwok
    Hi CADMama.
    I think they should just go ahead and move to 2007 and quit the 2000 ****. IMHO of course!
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Hmm. Odd. There seems to be some extraneous xdata associated with the wide polyline.
    Pline in block after explode:
    Command: xdlist
    Initializing...
    Select object:
    Enter application name <*>:
    * Registered Application Name: ACAD
    * Code 1000, ASCII string: ASC_BOUNDS
    * Code 1002, Starting or ending brace: {
    * Code 1070, 16-bit integer: 19
    * Code 1005, Database handle: 12A4A
    * Code 1002, Starting or ending brace: }
    Object has 16352 bytes of Xdata space available.
    Polyline after refedit/explode pline/pedit w/refclose/explode:
    Command: xdlist
    Initializing...
    Select object:
    Object has 16361 bytes of Xdata space available.
    Was this part of a lisp routine with reactors at one time?
    Edit: ps. the block moved without crashing after doing the refedit, also.
    0,0,0 The Origin
    8,570
    Also, deleting the pline (from cutblk1), replacing it with a new pline and redefining the block stopped the crash.
    Member evan's Avatar
    2003-11
    5
    Quote Originally Posted by CADMama
    Any ideas?
    We ran this through the ODA's recover process, and found/fixed a problem. Take a look, and see if it works.
    Evan
    Lost
    1,473
    Hi Evan,
    What is an "ODA recover process"? I haven't heard of that before.
    Earth
    9,805
    Quote Originally Posted by timcreary
    Hi Evan,
    ODA = Open Design Alliance
    See also:
    http://www.opendesign.com/
    http://www.evanyares.com/
    R.K. McSwain | CAD Panacea |
  1. INTERNAL ERROR: !dbobji.cpp@7319: eNotOpenForWrite
    By eddie9024535672 in forum AutoCAD General
    Last Post: 2013-09-04, 10:30 PM
  2. INTERNAL ERROR: !dbobji.cpp@6769: eNotOpenForWrite
    By rlehman.124981 in forum Software
    Last Post: 2008-12-17, 02:17 PM
  3. INTERNAL ERROR: !dbobji.cpp@6769: eNotOpenForWrite
    By mserapiglia in forum Software
    Last Post: 2008-05-20, 09:41 PM
  4. Error when running sub - eNotOpenForWrite
    By bweir in forum Dot Net API
    Last Post: 2006-10-23, 03:54 PM
  5. eNotOpenForWrite
    By tomdillenbeck in forum ACA General
    Last Post: 2005-06-02, 10:59 AM
