Thread: Easy way to set-up Support File Search Paths
    2005-09
    Reading, PA
    213
    Question Easy way to set-up Support File Search Paths
    I don't know if this was ever asked or not, but I'm going find out, I suppose. I'm adding several new folders to AutoCAD's Support File Search Path. I can only select one at a time. Is there anyway I can set AutoCAD to remember the last place I was at, similar to 'Open' and 'Save', instead of having to go back to the root (C directory and starting all over again?
    I did try REMEMBERFOLDERS, it is set to 1 and has no effect.
    Earth
    9,805
    Default Re: Easy way to set-up Support File Search Paths
    Not that I know of.
    Are you doing this for one machine or several?
    One machine shouldn't take too long. Any more than that and you can automate this task in a variety of ways.
    R.K. McSwain | CAD Panacea |
    2005-09
    Reading, PA
    213
    I have to do it on about a dozen machines. I don't know much about automating something like this, I'm not a programmer by any sense of the means.
    Earth
    9,805
    If you can copy and paste code, take a look at this thread:
    http://discussion.autodesk.com/threa...sageID=4982432
    If you are not sure what to do with lisp code, take a look at:
    http://www.cadtutor.net/forum/viewtopic.php?t=2942
    If you have a centrally located, common "acad.lsp" that each machine reads at startup, just include that code in there. Then, the support file search paths will be reset each time AutoCAD starts, eliminating a lot of problems. Here is how to do that:
    http://rkmcswain.blogspot.com/2006/0...setup-and.html
    Good luck.
  1. Trouble with Support File Search Paths
    By JGARZA0422 in forum AutoLISP
    Last Post: 2013-07-21, 03:45 PM
  2. Replies: 30
    Last Post: 2013-07-10, 03:13 PM
  3. 2012: Disappearing Support File Search Paths
    By Darren Allen in forum AutoCAD Customization
    Last Post: 2013-04-03, 04:11 PM
  4. 2011: Windows Env Vars in Support File Search Paths
    By mcnamac in forum ACA General
    Last Post: 2011-03-03, 05:54 PM
