Results 1 to 10 of 12
Thread: Create a Tool Palette in ADT 2007 like a steel building_M tutorial
    2006-03
    8
    Default Create a Tool Palette in ADT 2007 like a steel building_M tutorial
    How can i create a tool palletes in autocad architetural 2007 like a steel building_M tutorial, but with another beam and channels..
    tnx in advance.
    13,656
    Default Re: Create a Tool Palette in ADT 2007 like a steel building_M tutorial
    Hi "m0li3ri3" ( Sorry, I do not know your real name )
    Please note I have *moved* this thread from the AutoCAD Customization forum to this one, as I believe it will be better served here.
    Thanks, Mike
    Forum Manager
    Digital Delivery Director Brian Myers's Avatar
    2003-02
    Stillwater, Oklahoma
    1,819
    Quote Originally Posted by m0li3ri3
    tnx in advance.
    I'm not sure I understand your question, do you want to know how to create a toolpallete or are you looking for a specific layout/content?
    2006-03
    8
    Quote Originally Posted by Dilbert
    I need to create a log like a beam or channel or angle, similar to the tutorial steel building_M toolpallete.
    When u work them they´re in 3d form.
    That it!!!!
    i hope u can understant now!!
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    That it!!!!
    Where are you getting this tool palette from? If we can find this palette then we will have a common ground. Most users on here use imperial not metric so someone like myself would need to load the metric set first and then look for the palette you are referring to.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2002-09
    Madison, WI
    5,687
    If I understand your question, you want to create a tool pallet that will have the structural member style pre-selected for you, sim to the ootb "Walls" tool pallet. I think.
    2006-03
    8
    2005-07
    2,356
    You will need to create a new structural member style, insert it into a new drawing and save it with your other tools. Then open the drawing and drag it onto the tool palette.
    Check out this AU handout for more info on tool palettes http://www.augi.com/education/auhand...004/BD31-3.zip
    Also take a look in the ADT help, do a search for creating custom structural members.
    Hope this helps.
    2006-03
    8
    tnx ill see and post here.....
    2015-12
    4,730
    If you cannot find the shape you want in the Structural Member Catalog, you can create your own style using the Structural Member Style Wizard with the dimensions you desire. You can find the above two option on the Format menu.
  1. Create a new Tool Palette
    By avinash patil in forum Bridging the Gap: LISP -> .NET -> LISP
    Last Post: 2014-07-07, 06:20 AM
  2. ADT 2007 place steel objects on a Tool Palette
    By SCOTT.99883 in forum ACA General
    Last Post: 2007-04-20, 03:25 PM
  3. Create a flyout on a Tool Palette?
    By rstiles in forum AutoCAD Customization
    Last Post: 2006-10-28, 05:47 AM
  4. Create new button on tool palette
    Last Post: 2006-08-07, 01:29 PM
  5. Tool Palette tutorial
    By thillhouse in forum Training
    Last Post: 2006-03-11, 02:45 PM
