How would you create a cornice that slopes on top and the bottom portion is straight? See the attached file. Thanks
I'd make it "in place" and use a sweep with a 3d path. See image:Originally Posted by BomberAIA
Chris
SOM | New York
Hey, nice rendering !Originally Posted by BomberAIA
beegee
I think that you'll need to do an inplace (wall hosted if you like) family to model that condition. You're talking about the "gable" fascia in the distance down the side of the building, not the foreground right?
Yes, if you look at the rendering, it's towards the left. Also look at my file. Thanks
I think you could do the 3D sweep like Z suggests for the "cap". Use a straight wall sweep for the horizontal portion, all the way across.
Infill the "gap" between the two elements with an in-place wall hosted family that would just be an extruded solid, the depth of which would match your horizontal sweeps fascia less cornice crown.
Does that make sense?
