Results 1 to 8 of 8
Thread: View .PLT files
    Member Slash's Avatar
    2004-02
    39
    Question View .PLT files
    I know theres no CAD allowed in here but the Help, Tips and Tricks forum doesn't let me post a new thread.
    Basically, ive got an e-mail that has 10 attatchments in the form of PLT files. How can I open them?????
    Ive tried renaming them to DWG but doesn't work, and when i double click on the icon, autocad pops up and say darwing file invalid.
    Is there any way i can opem them?????
    Bob
    13,624
    1 members found this post helpful.
    Default Re: View .PLT files
    Quote Originally Posted by Bob
    Hi
    I take it you are referring to "Forum Tips & Tricks", I believe that Forum is read only and is used by the Forum Manager/Admin etc to post useful info that relates to using the Forums; small print reads "Tips on using Forums and getting the most out of the features".
    You need a Viewer that reads PLT files (probably some form of HPGL) -
    ViewCompanion
    CADwizz
    AutoVue
    ABViewer
    An internet search will turn up a lot more products, the above is just to get you going in the right direction.
    If you have Express Tools you might want to take a look at the command PLT2DWG -
    PullDownMenu: Express -> File tools -> Convert PLT to DWG
    Note - this command is very limited.
    Have a good one, Mike
    Last edited by Mike.Perry; 2004-06-07 at 11:01 AM. Reason: Answer Bob's first statement
    13,624
    Hi Bob
    Please note I've *moved* this Topic (Thread) from the CWC Forum to this one as I believe it would be better served here.
    Thanks, Mike
    Forum Moderator
    2004-02
    39
    thanks mike, im using autocad lt 2004 if it helps
    13,624
    Quote Originally Posted by bob-kalsi
    Hi
    I believe AutoCAD LT doesn't have Express Tools (have never used that product so can't be 100% about my statement).
    Regardless of that, I think you really require some kind of Viewer, I'll let others recommend their favourites....
    The Silent Type todd.69291's Avatar
    2016-02
    Aurora, Colorado
    56
    reprodesk is a good software for viewing PLTs
    http://www.bps.com/reprodesk.htm
    Enjoy, Todd
    2004-02
    39
    Quote Originally Posted by todd.69291
    Enjoy, Todd
    Thanks Todd, we can view the files now. However, do you know if i can import them or copy them onto autocad so that i can modify them?
    Bob
    13,624
    Hi
    Some Viewers will let you covert to DXF format, you can then import to AutoCAD
    OR
    Take a look at the following utility -
    HPGL2DXF
    Note - with the above methods you will be able to create a DWG file from your PLT file, but be aware that the results won't be perfect and some clean up work will probably be required.
  1. View Multi Files at once / Separate View Windows
    By Inventor Wishes in forum Inventor Wish List
    Last Post: 2012-09-12, 06:54 AM
  2. What are you using to view DWF files?
    By Mike.Perry in forum Design Review - General
    Last Post: 2006-10-29, 08:07 PM
  3. What are you using to view DWF files?
    By Mike.Perry in forum DWF Viewer - General
    Last Post: 2006-10-28, 03:37 PM
  4. How do I view and plot PLT files?
    By dlash in forum AutoCAD LT - General
    Last Post: 2006-04-05, 09:00 PM
  5. View dwf files
    By jpeck in forum DWF Viewer - General
    Last Post: 2004-09-22, 01:50 PM
