Results 1 to 10 of 10
Thread: Object open for read!
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    559
    Question Object open for read!
    I hate drawings that were not organized on layers.
    and so i wish to write a program to monitor newly added objects.
    i thought it would be as simple as this;
    Private Sub AcadDocument_ObjectAdded(ByVal Object As Object)
           If TypeName(Object) = "IAcadDimRotated" Then Object.Layer = "Dim"
    End Sub
    This is supposed to be monitoring Rotated Dimension Objects and put them in the "Dim" layer, but it has this error when a rotated dimension is added.
    Run-time error '-2145386418 (80200004e)';
    Object was open for read.
    Does anybody know how to fix this?
    Shielbern Bolalin
    Architectural 3D Renderer
    “A clever person solves a problem. A wise person avoids it.”
    1879-1955
    Adelaide, South Australia
    116
    Default Re: Object open for read!
    This is the problem with the ObjectAdded event that you cannot modify the returned object. Rediculous but true.
    I have a similar situation where I want to remove specific XData from copied objects. I use a collection with the help of the BeginCommand & EndCommand events to collect and modify the objects. One thing that complicates the issue is no CommandCancelled event as the copy command can be cancelled with objects still being created. Below is my code. Note that it also has to check commands that have a copy option within them.
    Regards - Nathan
     Option Explicit
    Private objCollection As Collection
    Private Sub AcadDocument_BeginCommand(ByVal CommandName As String)
    Dim Object As Object
    Dim intXdatatype(0) As Integer
    Dim varXdata(0) As Variant
    If Not objCollection Is Nothing Then
    	For Each Object In objCollection
    		'Start remove XData
    		On Error Resume Next
    		intXdatatype(0) = 1001
    		varXdata(0) = "E3-DEFINING-POINT"
    		Object.SetXData intXdatatype, varXdata
    		varXdata(0) = "TEXT_HEADER"
    		varXdata(0) = "TEXT_FRAGMENT"
    		On Error GoTo 0
    		'End remove XData
    	Next Object
    	Set objCollection = Nothing
    End If
    Select Case CommandName
    	Case "COPY", "PASTECLIP", "SCALE", "ROTATE"
    		Set objCollection = New Collection
    End Select
    End Sub
    Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
    		'Start remove XData
    		On Error GoTo 0
    		'End remove XData
    	Next Object
    End If
    End Sub
    Select Case ThisDrawing.GetVariable("CMDNAMES")
    		If TypeOf Object Is AcadText Or TypeOf Object Is AcadBlockReference Then objCollection.Add Object
    End Select
    End Sub
    2015-12
    Northern California
    583
    As the error suggests, the object is still being used by the creation code and cannot be edited while another operation has it open. One way to work around this is to have a Global Array or Collection that you can place the ObjectId into, then check if that Global object has anything in it in the EndCommand event and modify it there.
    2005-02
    Off the Grid
    559
    Thumbs up Re: Object open for read!
    thanks Miff for the idea. heres what i did.
    I defined a global variable that stores the ObjectID of a newly created object, and modify its properties in the EndCommand Event via ObjectToObjectID statement.
    heres the code:
    Dim ObjID As Long
          ObjID = Object.ObjectID
      End If
    End Sub
    Dim Obj As AcadObject
    Set Obj = ThisDrawing.ObjectIdToObject(ObjID)
    Obj.Layer = "Dimensions" 'assuming you already had this layer
    ObjID = 0 'clears the variable
    End Sub
    Viola!! a real-time Object's Layer Checker.
    Maybe I will complete this project by adding settings on which layer a certain object will go to. Thanks!
    Shielbern Bolalin
    1879-1955
    2005-02
    Off the Grid
    559
    Unhappy Re: Object open for read!
    The code I previously posted monitors only for a single object at each EndCommand Event. But some commands produce more objects such as dimcontinue... and much more, pasteclip. as miff's suggested, to put the ObjectID's in a global array, but I can't get it to work.
    Shielbern Bolalin
    1879-1955
    116
    Have a look at my code for using a collection of objects.
    Regards - Nathan
    2015-12
    Northern California
    583
    1 members found this post helpful.
    Here's one that I tested on DimRotated objects.....
    Dim objID As New Collection
            Dim I As Integer
            Dim oEnt As AcadEntity
            Do Until objID.Count = 0
                Set oEnt = ThisDrawing.ObjectIdToObject(objID(1))
                If TypeOf oEnt Is AcadDimRotated Then
                    'do whatever
                    Debug.Print "Got one!"
                End If
                objID.Remove 1
            Loop
    End Sub
      If TypeOf Object Is AcadDimRotated Then
          objID.Add Object.ObjectID
      End If
    End Sub
    2005-02
    Off the Grid
    559
    It works great!! thanks to you guys.
    Shielbern Bolalin
    1879-1955
    2008-02
    40
    Quote Originally Posted by miff View Post
            Dim I As Integer
                    'do whatever
                End If
                objID.Remove 1
            Loop
    End Sub
      End If
    End Sub
    pls could you help me with your above code retrieving the attributes of a block and modifiy them ?
    thks
    Turlock, CA
    5,356
    Quote Originally Posted by grobnik View Post
    thks
    Seach this forum for "getAttributes". Also, check the tips and tricks sticky thread at the top of this forum.
    C:> ED WORKING....
  1. Open Read-Only: The ability to open a worksharing enabled file in a read only mode.
    By Revit Wishes in forum Revit Architecture - Wish List
    Last Post: 2012-09-05, 07:02 PM
  2. Replies: 2
    Last Post: 2011-04-28, 02:04 AM
  3. open as read only
    By Ning Zhou in forum Revit Architecture - General
    Last Post: 2010-04-05, 05:08 PM
  4. No read only warning when dwg already open
    By CADMama in forum AutoCAD General
    Last Post: 2007-10-22, 06:19 PM
