Results 1 to 10 of 11
Thread: Create a custom Fence linetype
    Member Damian_E's Avatar
    2006-07
    Albury, Australia
    49
    Default RE: new linetype
    I'll post my question here as it's basically the same...
    I'm trying to make a fence linetype ie -- / -- / -- I have drawn it in cad, used the expresstools to make a line type, and the end result is the standard centreline, what am I doing wrong?
    Attached is a copy of the baseline drawing i used
    0,0,0 The Origin
    8,570
    Default Re: Create a custom Fence linetype
    In case anyone else is going to try - I took three line segments (-/-), moved them so that the left-hand end was at 0,0,0 and used mkltype. Result = a centreline.
    100 Club The VLG's Avatar
    2005-04
    on the up....
    137
    Quote Originally Posted by jaberwok
    Try this, I used a combination of makeshape & makelinetype
    2006-07
    Albury, Australia
    49
    Thank you, VLG
    I worked out how to make the linetype from your files.
    1) Can other linetypes be added to these files?
    2) Do i have to add this linetype file to everyone's pc's or can I just add it into the template? (I'm doing a College night course and we haven't got to customisation yet)
    3) Will I have to send the linetype file with the drawings if we send them to clients?
    Damian
    All AUGI, all the time Firmso's Avatar
    2006-03
    Here, Still
    549
    Try this Linetype I created for my site plan fence. hope it is what you are looking for
    2006-03
    Here, Still
    549
    Quote Originally Posted by de.116525
    Thank you, VLG
    Damian
    No, you don't have to do anything you are asking.
    Just make sure you do a Etransmit command and send everything that is compiled by it and send everything to whom you are sending it. Mainly it's the Fonts that you have to worry about.
    The person recieving the file will have to follow the instructions on the .txt file generated by the etransmit to make sure he/she is seeing the same thing you are when viewing the drawing.
    2006-07
    Albury, Australia
    49
    Thanks Firmso, as the 'designated' cadd / I.T. Manager wouldn't I have to add the linetype somewhere for the rest of the office to use it?
    2006-03
    Here, Still
    549
    Of course, if you already have a library or sort that you've created in your server for everyone to access, by all means drop it in. If you don't already have, go ahead and create one so everytime you have a project that needs it, just browse to it and load.
    As for giving dwg's to other persons outside your realm of connectivity, you do not need to send them the linetype files cuz it should already be preloaded into the CAD file itself when you inserted the linetype or browsed/loaded.
    2006-07
    Albury, Australia
    49
    Ahh ok, just soo much to get my head around, Thank you
    2005-04
    on the up....
    137
    Thank you, VLG
    Damian
    Glad I could help, I think all of yer questions have been answered already.
    If you send the drawing to someone without the ancillary files then it will open just fine, they will get a missing file alert but they just have to cancel the window & the drawing will open fine.
    For your own organisation I would suggest putting the files on to the pc that will be using the line, just so they drawing opens quickly for them & they won't get p'ed off & try to lynch you.
  1. 2014: Create a custom linetype with two colors
    By boyerd492098 in forum AutoCAD General
    Last Post: 2015-05-23, 10:22 PM
  2. Create a custom Sheet Pile LineType
    By Jay Zallan in forum AutoCAD Customization
    Last Post: 2010-06-17, 03:29 PM
  3. Create a custom Linetype - silt fence
    By gcameron in forum AutoCAD Customization
    Last Post: 2007-06-21, 10:40 PM
  4. Create a custom linetype with an Arc in it
    By tyeelaw13 in forum AutoCAD Customization
    Last Post: 2006-07-14, 03:49 PM
  5. Create a custom bold dot linetype
    By nanoaguilar2000 in forum AutoCAD Customization
    Last Post: 2004-09-28, 06:19 PM
