Results 1 to 9 of 9
Thread: Cookie Cutter Trim
    I could stop if I wanted to andy.manninen's Avatar
    2015-10
    @ _ork
    304
    Exclamation Cookie Cutter Trim
    This was mentioned in passing back in 2005 but i though i would re-iterate. I believe by AutoCAD 2005(?) the cookie cutter trim command has been taken out of the express menu and is now command line only. To access the command, type in EXTRIM in the command line. I've had about three people come to me looking for this command over the last month so i thought i would remind everyone where this useful tool is.
    For those who have never used the cookie cutter trim (EXTRIM) before, its a great tool to trim out a small part of a large complex drawing or for trimming a hole in a complex drawing. Just make a polyline, rectangle or circle of the area you want to trim around/ in. type EXTRIM and click outside the rectangle to trim everything outside, or click inside the rectangle to trim everything inside. On large complex drawings this is most useful when used in conjunction with a copy with base point. So for instance, your make a rectangle, trim all outside, leaving unconnected lines and such outside the rectangle and then use the copy with base point to copy out the objects left inside the rectangle, make a new drawing and paste to base point. done! sounds like a long process but it takes only a few seconds. Hope this helps,
    :Cheers:
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Cookie Cutter Trim
    Just a note, this will only trim objects that are crossing the selected boundary. Any entities not crossing the boundary will not be affected.
    2015-10
    @ _ork
    304
    Quote Originally Posted by Opie
    Right! so if you copy with base point the objects in the rectangle you can paste it into a clean drawing and get away from selecting and deleting all the bits and pieces outside the box! Thanks for helping clarify!
    :Cheers:
    2004-06
    49
    Andy,
    This is a great tip. I take it that it is not avalible in the lite version?
    Thank you,
    Roland
    0,0,0 The Origin
    8,570
    Quote Originally Posted by kb3cxe
    Andy,
    Thank you,
    Roland
    Up to and including 2006LT - no.
    2007LT - I don't know but I doubt it.
    I could stop if I wanted to Doodlemusmaximus's Avatar
    2005-04
    RAT HALL
    298
    think thats the trouble with diet CAD you lose so many of the nice features you're used to
    2006-01
    202
    Great little command which suprisngly few people seem to be aware of.
    Beware of lines of which only slightly extend beyond the cutting line by a very small amount. They will likely not be trimmed using this command. Also I have found that any dashed lines that cross the cutting objects will not be trimmed if the gap in the dash intersects the two lines. I always quickly change my ltscale prior to using extrim to avoid this issue.
    Hope this gives a heads up
    13,656
    Hi
    ExTrim is an Express Tools command, therefore not available in AutoCAD LT ( unless you have a Third Party application that enables such things as LISP, VBA etc ).
    As far as I know ( which means nothing ), the Express Tools - Layer commands and ChSpace command were the only Express Tools commands ported from Express Tools into the core product of AutoCAD 2007 and AutoCAD LT 2007.
    Have a good one, Mike
    100 Club Brian Benton's Avatar
    2015-06
    at home
    183
    It's amazing how so many "problems" never go away. I just had a user ask me where the cookie cutter trim command went. But let me explain, we are currently upgrading from AutoCAD 2004 to AutoCAD 2008, so, some of this is understood. But I still find it interesting. thanks for the post as I couldn't remember the exact command (extrim) as I typically don't use it. I love AUGI.
  1. Viewport cookie cutter
    Last Post: 2015-06-18, 11:39 AM
  2. cookie cutter trim
    By bapho in forum AutoCAD General
    Last Post: 2009-05-14, 07:11 AM
  3. Cookie cutter trim
    By patricia.ellistone in forum AutoCAD Map 3D - Wish List
    Last Post: 2007-10-17, 02:51 PM
  4. Express Tools - Cookie Cutter Trim
    By eleonard in forum AutoCAD General
    Last Post: 2005-11-16, 10:21 AM
  5. Cookie Cutter Trim
    By BCrouse in forum AutoCAD General
    Last Post: 2005-01-27, 11:16 PM
