Thread: All blocks come in with Plot Style = Normal? (Named Plot Styles)
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Unhappy All blocks come in with Plot Style = Normal? (Named Plot Styles)
    This one's been driving me crazy.
    I've been having strange problems, and I think I've finally tracked it down to what seems to be a bug in 2007.
    We use Named Plot Styles. Whenever we insert a block - ANY block - the properties for the block get Plot Style set to Normal. In all previous versions of Autocad, blocks were inserted using the current plot style. We almost always have the current plot style set to "By Layer".
    Most of the properties for most of the objects in most of our blocks are set to "By Block". This is by far the most flexible and powerful option in most situations. But that means that having all blocks come in with their plot styles set to "Normal" is causing a huge headache. We want these blocks to come in with plot style set to "By Layer".
    Anyone else notice this issue? Found any sort of workaround, short of manually setting the plot style of every block to "By Layer" after insertion? (We could also go through our entire block library, changing the plot styles of every object in every block to something other than "By Block", but for reasons that are probably obvious, we don't want to do that.)
    2004-02
    Colorado
    1,986
    Default Re: All blocks come in with Plot Style = Normal? (Named Plot Styles)
    As another datum point, this problem only occurs if you select "Specify On Screen" for any of the properties in the INSERT dialog box. If you do not select "Specify On Screen" for any of the properties, the block will be inserted correctly (with the current plot style). It is only when one or more of the options has "Specify On Screen" selected that the block is inserted with Plot Style = Normal.
    2004-02
    Colorado
    1,986
    This is also a problem with Tool Pallettes. All blocks inserted with Block Tools come in with Plot Style = "Normal", regardless of how the properties of the Block Tool are set.
  1. Specify the Plot Style for certain entities in a Named plot style drawing
    Last Post: 2014-10-28, 11:52 AM
  2. Named Plot Styles (STB Files)
    By sinc in forum CAD Management - General
    Last Post: 2009-02-25, 06:56 AM
  3. Tables and Named Plot Styles
    By james.emoore in forum AutoCAD Tables
    Last Post: 2008-04-08, 01:28 PM
  4. Named Plot Style OR Color Depemdent Plot Style
    By Masroor Javid in forum ACA General
    Last Post: 2007-09-11, 02:16 PM
  5. NAMED PLOT STYLE TABLE
    By atsjm in forum AutoCAD Plotting
    Last Post: 2004-09-19, 10:18 PM
