Thread: Freeze Layers, Save and Close DWG, Open DWG, Layers are Thawed
    2005-03
    10
    Default Freeze Layers, Save and Close DWG, Open DWG, Layers are Thawed
    I'm working in AutoCad 2006. I froze certain layers in a drawing file, saved the file and closed it. When I open the file, the layers that I froze were thawed. This seems illogical to me- I expect the layers to remain frozen when I reopen the file. Is there a way that I can achieve this?
    2005-07
    2,356
    Default Re: Freeze Layers, Save and Close DWG, Open DWG, Layers are Thawed
    Do you have lots of layer filters in the dwg? If so and you dont use them delete them and see if it makes any difference.
    But yes you are right layer states should be maintained between sessions.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Are the affected layers from an XREF file? You may try this thread "Frozen Layers within Xref come in Unfrozen". The system variable would be VISRETAIN.
    13,656
    Hi "apx8" ( Sorry, I do not know your real name )
    Please note I have *moved* this thread from the CAD Mgmt. General forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
  1. Replies: 7
    Last Post: 2018-04-13, 03:57 AM
  2. Viewport Layers Frozen/Thawed states
    By Mike Y in forum AutoLISP
    Last Post: 2015-08-28, 10:11 AM
  3. have to regen to see thawed layers?
    By ReachAndre in forum AutoLISP
    Last Post: 2008-10-30, 07:35 PM
  4. I Freeze Layers on the Sheet but wont Save what I Freeze
    By jrosario in forum AutoCAD General
    Last Post: 2008-02-15, 11:48 AM
  5. Replies: 3
    Last Post: 2006-09-22, 08:22 PM
