Results 1 to 6 of 6
Thread: Audit
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,129
    Default Audit
    What exactly does audit fix in a drawing? Ive looked through the help files and didnt find much except how to run audits.
    curious minds want to know
    2002-09
    Madison, WI
    5,687
    Default Re: Audit
    The audit command trys to fix "Corrupt" data. Audit can make a file better, or make it worse depending on what happend to it. I'm not a programmer so I can't give you specifics, but I know it's not a bad thing.
    2005-07
    2,356
    Default Re: Audit
    When a project or a drawing is audited, the styles and display settings in the project drawing are compared with those of the project standards, and any out-of-synch standards will be reported.
    Out-of-synch standards can appear in these cases:
    A style or display setting in a project drawing has changed and needs to be updated with the correct version from the project standards.
    A style or display setting in the project standards has changed and needs to be updated in the project drawings.
    Not standardized styles and display settings have been introduced in a project drawing.
    You could for example run an audit on drawings that come from contractors, or from other outside sources. Before you synchronize the drawings with the project standards, you first want to look at what actually is different between the drawings and the standards.
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Default Re: Audit
    hahaha!!! That's right! I never thought about there being 2 different types of audit availbe in ADT.
    Which Audit are you wondering about?
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2006-04
    1,129
    Default Re: Audit
    The fixing drawings audit. Our standards arent far enough along to try and match drawings yet. I know Ive run it, and its come back with some fixed errors before, I was just curious what exactly it is that is being fixed.
    2015-12
    4,730
    Default Re: Audit
    Quote Originally Posted by Chad_C
    Have you ever used the LIST command to check out various properties on an object in a dwg? Have you noticed how every one has something called a "handle"? That's one of the things audit checks is to make all objects handles are in the proper location and associated correctly. Another thing is it looks to check on blocks or items that have been copy/pasted from one drawing to another.
  1. Why so many errors... why do I have to always run AUDIT
    By EngME in forum AutoCAD Civil 3D - General
    Last Post: 2009-09-30, 04:53 PM
  2. AUDIT IN ACADDOC.lsp
    By dbrownson in forum AutoLISP
    Last Post: 2008-03-24, 02:12 PM
  3. Run audit at every Qsave
    By jdmc in forum ACA Wish List
    Last Post: 2006-09-24, 01:04 AM
  4. Audit Entities
    By de-co1 in forum AutoCAD LT - General
    Last Post: 2006-09-01, 02:19 AM
  5. Audit?
    By truevis in forum Revit Architecture - General
    Last Post: 2005-08-26, 06:33 PM
