Thread: Error message when loading VBA macro - Could not load an object because...
    2004-05
    27
    Unhappy Error message when loading VBA macro - Could not load an object because...
    Hi all,
    I’ve just installed AutoCAD 2007 – Network version – on to a computer, which went ok. However, when I try to load a VBA macro a keep getting this error message.
    Microsoft Forms
    Could not load an object because it is not available on this machine.
    Any ideas.
    Mike
    Earth
    9,805
    Default Re: Error message when loading VBA macro - Could not load an object because...
    Most likely, the VBA project contains a refererence to a control that is not installed on this machine. If you are not sure how to find this out, can you post the DVB here, and let us take a look at it?
    See also: http://tinyurl.com/pmux8
    R.K. McSwain | CAD Panacea |
    AUGI Addict MikeJarosz's Avatar
    2015-10
    New York NY
    1,497
    Make sure you have loaded the type libraries. Specifically in your case, Microsoft Forms 2.0 Object library. You can find the type libraries in the VBA editor window under tools/reference/
    2013-11
    4
    I have the exact same problem occuring. See Here:
  1. Replies: 2
    Last Post: 2009-12-14, 04:55 PM
  2. Replies: 8
    Last Post: 2009-10-27, 12:03 PM
  3. Open Multiple Drawings Causes Macro Error Message
    By svanderputten in forum AutoCAD Mechanical - General
    Last Post: 2007-10-29, 01:15 PM
  4. 3ds Max 9 - Error Message: "Error loading biped"
    By stusic in forum 3ds Max - General
    Last Post: 2007-07-14, 08:17 PM
  5. Replies: 2
    Last Post: 2006-06-20, 05:12 PM
