Thread: Creating a Custom CUI & Tool Palette advice
    2005-12
    Hartford, CT
    394
    Default Creating a Custom CUI & Tool Palette advice
    Over the past several months I have been give allot of advice from a office employee about AutoCAD 2006, specifically on how to set it up. He touts himself as an expert on the subject, and even has a nice certificate from Autodesk University to back up his claims. However, so far almost every piece of advice or direction he has given me has turned out to be a bust. With all that said I would like to thank all the users of this forum. With out your expertise I don't know what I would do.
    So I would like to hear some advice on the best way to create an office custom CUI. I want to have a standard company CUI on the network (enterprise CUI) that contain all the standard company menu's, tool bars, and tool pallets. They will all be read only so users cannot fuss with them. The main CUI file will be located on each users local machine so users can create there own work spaces and tool pallets.
    Based on some advice, I took my company standard mnu file and used that as the base of the office CUI. In that CUI I then have the ACAD.CUI and the Express Tools CUI loading as partial CUI files. For some reason that just seems back wards. Wouldn't it make more sense to use the ACAD.cui an load my company standard CUI and the express tools CUI as partials?
    I would also like users to be able to create there own local custom tool palettes & work spaces while also having company standard tool pallets and work spaces. I want the company standard tool pallets to be read only. Any advice?
    Tim Mailloux
    2001-03
    13,499
    Default Re: Creating a Custom CUI & Tool Palette advice
    Hi
    Have you reviewed / seen the following...
    * CUI - Notes on the philosophy of CUI
    * Tool Palettes - Palette Path - Toolbar Code to change path
    Have a good one, Mike
    Houston
    7,543
    Quote Originally Posted by tim.101799
    Wow. I had to do a double take and make you were not from my office...
    We have "acmap.cui" loaded as the main (for Land Enabled Map) and "land.cui" as the main (for LDT). This is how it is OOTB. The downside (and a huge flaw in the CUI system) is that if a user creates a toolbar or menu - it gets dumped in "acmap" or "land" - which of course is subject to being overwritten with a SP, repair, etc.
    R. Robert Bell's thread (to which Mike pointed you) - says to make CUSTOM the main - this works so that if the user creates something - this is where it get dumped. However, this is difficult at best to implement in a vertical like LDT, with other menus like Raster Design, ToolPac, etc.. I think I even remember Mr. Bell saying something to the same effect.
    Tim Mailloux
    Set your Tool Palette path (in Options) to a network location that only you have WRITE access to. Everyone else should be set to read-only. Create your tool palettes and modify as needed. Point everyone else to this same network location. There is a way to point to this network location AND a local location so that users can still use/modify/create their own tool palettes. If you are interested, I can tell you how I do it or if you are interested in Mike's link - Try this and save about 5 clicks: http://forums.augi.com/showthread.ph...863#post108863
  1. Put sub-assemblies into a Tool Palette or the Custom Tool Catalog?
    By justin.d.ehart in forum AutoCAD Civil 3D - Corridors
    Last Post: 2007-06-05, 03:52 PM
  2. Custom Flyout on a Tool Palette
    By chris.kulhanek in forum AutoCAD Customization
    Last Post: 2006-07-18, 03:00 AM
  3. Creating new Tool Palette Catalogues
    By mf in forum AutoCAD Customization
    Last Post: 2005-04-07, 11:55 PM
  4. Creating Tool Palette from Blocks
    By mgagnon in forum ACA General
    Last Post: 2005-04-06, 09:00 PM
  5. Creating 2D tool palette content...
    By kookycad in forum AutoCAD Customization
    Last Post: 2004-07-13, 04:03 AM
