Thread: Slot Window through Two Wall Types
    2006-04
    Baltimore, MD
    380
    Default Slot Window through Two Wall Types
    I am in the process of making some minor design modifications to an existing Revit model. In the hand sketch I am working off of, the designer has a tall, slot-like window that runs between two different wall types. (See the attached sketch.) One is brick veneer on a CMU backup, the other is metal panels on metal studs. What would be the best way to approach this? Thanks for your help.
    2001-07
    Phoenix, AZ
    1,003
    Default Re: Slot Window through Two Wall Types
    I can't get the image to show up in my browser but if the two walls can be made to "touch" in plan (and you might need to add an air space component to one of the walls or even add a new wall that is nothing but air) you can "join geometry" between the walls and the openings will transfer.
    2006-04
    Baltimore, MD
    380
    I didn't even need to add any airspaces, and I got the walls joined and the window to cut both walls. I guess I just overlooked that. Thanks!
  1. Door and Window Types
    By tampac66 in forum Revit Architecture - General
    Last Post: 2010-06-21, 08:51 PM
  2. Scheduling out window panel types and areas in a curtain wall schedule
    By wcaramella in forum Revit Architecture - General
    Last Post: 2008-01-26, 03:07 AM
  3. Complex Wall and roof types types
    By Andre Baros in forum Revit Architecture - Wish List
    Last Post: 2004-08-19, 09:12 PM
  4. Door Types and Window Types
    By cgrover in forum Revit - In Practice
    Last Post: 2004-07-23, 02:58 AM
  5. Two Wall Types and a Window
    By jsykes12 in forum Revit Architecture - General
    Last Post: 2004-06-15, 05:21 PM
