Thread: Filled Region
    2002-08
    Sofia, Bulgaria
    158
    Default Filled Region
    Hi
    Can someone tell me how to use this parameter ? Is it just simple text parameter ?
    best regards
    niki
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: Filled Region
    The pulldown arrow lets you select from the list of fill patterns. To add more fill patterns you do that under settings>fill patterns. Once you add them they are available. If you are talking about the button next to the pulldown arrow, then that is a button that lets you assign one parameter = to another, this is done in the family editor where you may want the width parameter to = 1/3 the height parameter or something like that. I'm not sure if you can use it to set the fill pattern type to equal another parameter.
    Scott D. Brown, AIA
    BECK
    2002-08
    Sofia, Bulgaria
    158
    Thank you Scott for the answer. But I'm asking about the parameter that can be assigned to the Fill Pattern ? I'm just curious about its purpose.
    best regards
    niki
    2002-02
    St. Louis, MO
    4,695
    That parameter does not yet seem to be implemented. The value assigned is discarded.
    2005-05
    66
    its been there from some days now....and not been addressed...?!
    any developments till date with regard to the parameter that couldnt be accesed?
  1. FILLED REGION
    By Sissy20020 in forum Revit Structure - General
    Last Post: 2012-02-27, 03:02 AM
  2. filled region
    By Galadriel in forum Revit Structure - General
    Last Post: 2010-05-13, 02:38 PM
  3. Filled Region gets in the way
    By troy.crandell635379 in forum Revit Architecture - General
    Last Post: 2008-03-24, 07:24 PM
  4. Filled region to masking region?
    Last Post: 2007-08-15, 01:56 PM
  5. More Filled Region Q's
    By designer56644 in forum Revit Architecture - General
    Last Post: 2003-09-16, 10:06 PM
